junkyard motor, what should i pay?
#47
Last weekend I got a 95 300 I6 for $250 off craigslist. The engine came out of a wrecked truck and after I got the valve cover off, its a very clean engine! Best thing is I got it $50 less than a junk yard and did not have to pull it to boot! Junkyard engine hoists are not the "user friendly" kind....
#48
you'll want to drop the pan and check the bottom end. I would replace the oil pump b/c they seem to fail on these 300 I6's more often than other engines. rear main and water pump are a given in order to skip teadious maintence in the future.
Craigslist always has good deals for us ford guys... if you like CL try CZL! www.crazedlist.org
#49
sounds like a great deal. How many miles?
It had over 200K and all docs as it was a fleet truck. The guy I got it from got the truck for the cab and bed, keeped the engine and tranny(e4od) but ran out of room(like me). My friend got screwed on his E4OD rebuild and he may get the tranny from the guy depending on if he gets the sob that took his tranny and $$$......3 months his truck sits in my driveway now.....
I will be doing a ring and bearing overhaul and will replace oil pump,core plugs, water pump and ect... got the engine out best do it right 1st time!
Kinda wondering about the engine mounts on the 94/95 I6 engines, they look like the 80 to 86 engine mounts ( \ engine block / ). Not like the 92 engine my friend has and the 90 parts truck( --engine block --) <--- old days of ANSI grpahics there.
I have the I6 pedistals from a 90 truck to use but looks like I'll be hitting the junkyard to get the engine block brackets.
#50
if i change the jets, etc could i make it so it wouldnt run as rich, the only reason im getting this carb is cuz its from a buddy of mine for cheap
#51
Sounds good... Just didn't want you to "overspend" if you were buying parts new. Are you buying the Offey DP new?
#52
Do you mean the motor mounts, or the towers that are rivited to the frame? If you are talking about the motor mounts I would just buy new ones if I was you. Rock auto has them for $16ish each... New rubber/poly would be a better sound and vibration dampener... www.rockauto.com
#53
Local pick-u-part is less than $200 complete with all engine with FI parts for any gaser. AND it is ok to tear it apart and verify whever before you purchase. I would verify no water in oil then tear it down and determine bore quality and crank quality before I dropted my money on it. Plus they have a 30 day swap warantee. There is no way to run and engine. No $$ returned but you can pick another engine.
NORMAL junk yards are very pricy for the same item, almost any engine would run anyway unless it is broken and you can verify total destruction with visual mechanical inspection.
What have you got to lose; head for a pick your own parts type of place.
There are many in-line 6's in the local PP. AND they take the debit card!!
BUT I am in DALLAS.
NO I have no connection with them but I personally like a non rip-off deal.
BUT I am in DALLAS.
#54
i am getting the offey dp new probably, i found one in omaha but he wanted to sell the carb as well for 250 and i tried to talk him into just selling me the intake but he wouldnt
Do you mean the motor mounts, or the towers that are rivited to the frame? If you are talking about the motor mounts I would just buy new ones if I was you. Rock auto has them for $16ish each... New rubber/poly would be a better sound and vibration dampener... RockAuto Auto Parts
#55
#56
#57
Anyway, heres the engine I got.
Top end is clean and all water passages are good.
96inline
02-18-2016 09:42 AM
Fr. Frank
04-13-2009 08:31 AM
