You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I can't compare the HHR to the PT...never been in a PT Cruiser, let alone drive one. But this '10 HHR is a POS. It's got that dam self adjusting radio that will adjust the volume relative to background road/engine noise.
I have this on my 500, but it adjusts the volume per the speed of the car. I have it set to a lower setting so it's not so pronounced, but I actually like this feature.
Just dropping in to say hello, doing good over here. About to hit my halfway mark, ready to get home. Trying to get things in order for my truck so I can get some wrenching done!
__________________ Andy 2008 Expedition Eddie Bauer Arkansas Chapter Member
Good to hear from you Andy! Hope all goes well for you over there. Let me know when are getting home and I'll get that window and any other parts you need off of the truck for you.
Hopefully this is the last time in the sandbox! or at least that particular one..
Sure was windy last night and early this morning. Though it was great to spend a night out on the train without needing a jacket.
Quote:
Originally Posted by tojoski
I have this on my 500...
As in GT500?
Quote:
Originally Posted by mechmagcn
Uhhhh.... I think I'll stick with my old school stuff
AMEN! Though I am a sucker for satellite radio and in-dash 6 CD players. Kind of helps when you make a road trip into a "foreign land".
Quote:
I've got a cousin that's a SeaBee in Afghanistan. He told me a couple weeks ago that the unit that's rotating in to replace his reserve unit is going through their mobilization. I'm thankful for not only him, but guys/gals like you Andy. Y'all come back safe.
__________________
FTE Arkansas chapter member
1972 Ranchero GT (351C CobraJet intake)
2001 Explorer XLT 2WD
2004 F250 6.0L 2WD CC "Pavement Princess"
2007 Monaco Starwood SL 31BHD
2012 Focus SEL (Wife's ride)
Seen a little bit of rain going into KC this morning, but not lighting or thunder. For the record, when you get a "wheel slip" (similar to spinning tire on wet/icy pavement) and your running 50 mph....the rail is slick! Wheel slip on the locomotive is somewhat common below 15 mph just because the huge amounts of torque the traction motors are putting to the rail at a low speed. It's not very common once you get the ground speed above 25-ish.
__________________
Hey everyone! I think its been about 2 months since Ive been on here. Ive been working about all the overtime they will give me (still working it though) & spending more time with family & my other hobby.
Good news is I have another Ford in my yard. A '94 F150 2wd short bed with a 300 I6 & E4oD. First full week I ran it, I was getting 15.5mpg. Changed the oil, plugs, wires, cleaned up the connections on the cap & rotor then fixed 2 vacuum leaks. After all of that it jumped up to 17.3mpg. Now if I can keep it under 60mph I might be able to get 18mpg. I also have a slight problem with it shifting hard/late. I have all of the stuff to change the fluid & filter and hope that fixes it.
Still have my '82 F250 "tropical truck" even after pretty much selling it to a friend. That damn truck was driving me F'ing nuts for a several months. Still not sure of the actual problem but as long as it isnt on the cold side of cool outside, it will fire up & run great. When it acts up, I can get it fired up & idling good for a few minutes then it flat out dies. Figured out I was loosing spark. Small chance to get it to hit & stay running but I normally had to wait until it warmed up outside to drive it home from work. Or just call David & have him tow it home.
Also been trying to figure out what Im going to do with my '77 F250 4x4. Im torn between more or less restoring it with a little extra (engine work, dual T-cases, little lift & tires) or just building THE 4x4 I want. SuperCab longbed sitting on a Deuce & half frame, suspension & axles. Stuff a diesel in it (still can decide on that one either) & use the Rockwell T-case along with the one behind a diesel & auto. I know the Rocks are overkill for just about everything Im going to use the truck for but it makes more sense to over build it once than build the stock stuff a little tougher then break it only to dump more money in it. Im gonna stop here cause I could ramble on about that truck for another hour or two probably.
jgoodman6891 that's a good looking truck you've got there. I used to drive one almost like it ('94 with a chrome front bumper) when I first went to work for Caterpillar back in '96. That 351W would get on down the road, and I remember how shocked I was when it came to refilling both tanks and gas was 1.03 a gallon.
They found the Pavement Princess.
Trying to work out a couple of details of how I'm going to get her back to Fort's Myth from KC. I haven't seen photos of it, but according to the detective that went to look at it this morning...rear & front bumper and one battery is all that is missing. To say the least, it's been a busy day on the phone with a couple of different folks.
__________________
