Trailer lights aways on
Old 04-01-2011, 05:09 PM
canonsue's Avatar
canonsue
canonsue is offline
I have a 2011 Ford F-150 XLT. Thanks to the forum, I did take the fuses out of the glovebox and installed them. So trailer lights and blinkers work fine. I just purchased a small teardrop tailer. My problem is that the trailer lights are always on when plugged into the truck.They are on even when lights are off and key is out.
I am assuming that the problem is with the wiring of the trailer harness but I wanted to ask here first in case the problem might be with the truck. I have never had a trailer so I am unsure if the 7 prong plug is always hot. Obviously it is on my truck. Is this way it should be?
What do you think may be the problem?
Thanks,
-Sue
Old 04-02-2011, 10:12 PM
Rancheroracer's Avatar
Rancheroracer
Rancheroracer is offline
The 7 pin plugs typically have a + and a -, (12v pos & 12v neg). Sounds like the trailer plug is wired wrong.
Old 04-02-2011, 11:38 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Usually the BATT + is only hot with the key on. My 01 F150 was that way. I used it to charge the battery on my car trailer for my winch.
Old 04-02-2011, 11:50 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
The Chevy trucks have the charge wire hot all the time.
Old 04-03-2011, 07:25 AM
canonsue's Avatar
canonsue
canonsue is offline
It looks like the truck is the problem. A circuit tester shows that when the key is turned on both the power and the lights circuit is powered. It should only show that the power is on. I also hooked up my trailer to another vehicle and it worked correctly. Some how there is a feedback circuit that when the trailer harness is plugged into the truck and the key is out, the trailer battery lights up the running lights. Now I just need to convince my Ford dealer of the problem so I can get a warranty repair.
Thanks for all of the responses.
Old 04-03-2011, 04:50 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
I don't like that!! Fire hazard, plus you can get feedback from the trailer battery. I guess that's another reason I will never own a GM. Ford and Dodge have the better idea here.
Old 04-03-2011, 05:22 PM
MisterCMK's Avatar
MisterCMK
My biggest beef with that is that you can discharge the truck battery with a trailer hooked up. Then you are pooched.
It would be nice to have a timer or something like that to turn on the charge wire for a little bit but I suppose I could get off my duff and put a battery in the enclosed trailer to run the lights too. lol!
MDSuperDuty
1999 to 2016 Super Duty
04-27-2011 06:23 PM
southbound35west
11-30-2009 08:36 PM
Loudmouth LS1
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
15
07-25-2007 06:55 PM
solomon
1997 - 2003 F150
12-16-2005 03:30 AM
Quick Reply: Trailer lights aways on
