Front Leaf Springs
Front Leaf Springs
Would these work for a 97 350 psd in front or do I need to go heavier?
F250/350 Extra Heavy Duty Front Springs, Stock (Pair)
They cannot handle the odd angle and weird torque the TTB puts on them, Thats why the TTB springs are thicker.
A guy about 8 months ago put 350 springs on his 250 in here with TTB and wondered why it was sitting so low in the front all of a sudden.
Just food for thought.
From the factory that is probably true. But from a going to a spring shop and getting new springs they are the same.
I think the deal with the 250 springs is they are tapered springs, the center is really think and thins out as you work yourself away from the mounting u-bolts. Seen here http://broncograveyard.com/images/ca...DIESELFRNT.JPG
The f350 spings with solid axle is a straight spring as it does not have to deal with the twisting motion.
With that said, I have a add-a-leaf on the front and that is a straight spring with no breakage. The only thing I can fault it is the occasional squeak crawling over REALLY rough terain like driving across 8 inch ruts in a dried out mud pit. The heavy steel spring clamp that wraps around the oem springs will squeak under tis conditions(metal on metal) but nothing that I see that is worrisome.
product Display
click "accessories" for the add-a-leafs
product Display
Amphihauler
Ford Truck Parts for Sale
09-26-2016 10:25 AM
