View Poll Results: Here they are, who is it going to be? "Choose wisely..."
1.76%
3.53%
32
18.82%
3.53%
3.53%
71
41.76%
2.94%
41
24.12%
Voters: 170. You may not vote on this poll
the 2011 FTE "Wild Trucks" round One POLL
#31
This is why you never give your buddy the plasma cutter.
I love my ZF5 transmission. Awesome first gear
Intercooler for my bronco. Probably makes the one on Oreocreaming's truck looks small.
Its leaning up against a 40 inch tire for reference.
Ever try an engine swap in a apartment complex parking lot?? I wouldnt recommend it.
Everything nice and clean
#32
The 4bt in all its beauty
This is the main reason to never do a engine swap in a parking lot. Your *** will get towed.
Its also the fastest way to get more lift out of your bronco.
Had to put the 4bt in and out like 4 times to get the engine mounts mocked up. That thing is heavy and tall.
All done after the swap. This was the first time I ever did a engine and transmission swap. So i was happy that she would just move.
#33
#34
#35
Now with any good lift install you need some bigger meats to go on afterwards. Good thing i picked up these slightly used 36x13.5 R15 Irok Super Swampers.
But of course Murphys law always follows my bronco and i lost a tire on the way to the tire shop and broke a rim. So i had to source some new ones.
New rims and tires
New rims and tires
#36
Time for some more action shots. First offroading trip since the Diesel install and the lift was put on. She performed like a champ.
Buddy got water in his distributor
<iframe title="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/8_KRTVaYUjs" frameborder="0" allowfullscreen></iframe>
#39
my intercooler is as big if not a little bigger. its only 2" shy of being as tall as the diesel radiator, its outside to outside 10" wider then the radiator.
oh, honestly i think 1 month is a bit too long for a pole. people get burned out on it long before. 2 weeks keeps the interest alive and keeps the people in it scrambling for votes.
#41
day 1
day 2
about a month in
couple weeks later got the 37's
decided the front end had to go!
after this!
i had to do this
the tires sucked when pulling loads like this
so i had to do this
all this after new poly bushings on the cab and the whole suspension.
then needed cut out flares in the rear, added 04 powerstroke mirrors, power heated and blinkers integrated all on 1997 powerstroke doors to match the 1992 front clip and 1997 powerstroke tailgate.
before the 42's and the lift kit i did the full interior,
dynamat on the floor and roof to help keep the heat out and the cold in during the summer.
oh ya, and you can see in the tailgate pic i built a custom hitch, dual receivers for the 1 and 2 car trailers. 1/2" plate with 3x6x1/2" tube tying it all together. 18" drop hitch for my 1 car trailer, straight hitch for the 2 car. oh, ladder bars on the rear too to help keep the axle wrap to a minimum 1 1/2" .250 dom wall tubing with heim joints and a custom shackle on the front to prevent binding
oh, and the upgraded steering draglink to match the larger tires but doesnt take much load because ive got 2" full hydraulic ram for the steering. draglink is just to keep it CA dot legal
day 2
about a month in
after this!
i had to do this
so i had to do this
#44
#45
ya, they get loaded in the order they are going to be unloaded. im not a fan of shuffling cars when i dont have to.
