Rearend Whine
Old 04-01-2011, 03:22 AM
93_flareside's Avatar
93_flareside
93_flareside is offline
Rearend Whine
Please first see
https://www.ford-trucks.com/forums/1...-the-caps.html
Now, to explain my current dilemma. Everything is back together and seemed to be fine. But, now when I accelerate hard I get a rear end whine.
Could this be caused by the caps being flipped, or possibly not shimmed correctly?
I looked up the symptoms in the Ford service manual, and it said that the drive shaft was put in 90 to 180 degrees off. Would that actually cause a whine?
Thanks in Advance
Old 04-01-2011, 07:35 AM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
Originally Posted by 93_flareside
Please first see
Thanks in Advance
Sorry I can't advise you here, but I am just wondering how a drive shaft can be off by any degree at all. It's pretty straight forward in removing a drive shaft. There may be alignment marks for the spindle gears but that's about it. Or is it a balancing issue?
Old 04-01-2011, 09:17 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
Some people swear that you have to put the driveshaft back in the same position as it was removed. If not, you can get a vibration problem. Personally I do not subscribe to that theory. I have never had an issue R&Ring a driveshaft then getting vibration issues. But then again I do mark the positioning before removing......
I do not see the reasoning why driveshaft positioning creating a whining problem. Which bearings did you replace? What did the wear pattern look like when you reassembled it? What backlash did you use?
Old 04-01-2011, 10:32 AM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
That's what I thought too. I admit I have only had to remove a drive shaft twice- both times to replace U joints so in both cases I didn't have to remove the yoke from the differential, but I did from the transmissions. Didn't mark anything, didn't pay any attention to it at all [I can't remember for certain if the spindles had alignment grooves or not- I don't think they did], just removed, installed new u joints, and reinstalled the driveshaft. No issues in either case.
