O/D light flashing on E4OD!
Hey guys, I don't know if this is anything to be concerned about but as I pulled in I noticed the o/d light was flashing. I took it out of o/d about 2 days ago and it flashed for a little while then stopped. I took it in and out of o/d tonight and after 30 minutes it started to flash. Is it normal to flash some after being taken in and out of o/d??
i dont have an e4od but this usually means something is going to go somewhere. might just need adjusting of the fipl, friggin electronics. sorry to hear bro, hope its simple.
Edit, from reading around, the only reason it blinks is something wrong. You have to get the codes pulled so you dont just start replacing things!
I don't think its that big of a deal, if I remember correctly, It happened before and it stopped. I don't have hard shifting or anything and it is 15K miles old. I did spin the tires a few times for like 5 seconds each but I don't think that would hurt anything. Is there some kind of sensor on the IP I can adjust?
Thats never good!
Hey Snapon,
From what I understand there are only about 3000 things that can make this happen! Mine did it because the tach sensor was bad, the fipl can do it, I have heard word that burnt out tail lights can cause it, perhaps even the wrong kind of cream in your morning coffee! LOL. Safe play is to start with a code reader if you have access to one.
Mac.
Mac.
