Ignition module electrical wiring harness assembly - Ford Truck Enthusiasts Forums
Old 03-31-2011, 07:33 PM
Frenchy Frenchy is offline
Frenchy is starting off with a positive reputation.
Smile Ignition module electrical wiring harness assembly
I need to replace the ignition module electrical wiring harness assembly off of my 1983 Ford F-150 half ton truck that has a 5.8L 351W engine(electrical wiring assembly for the engine oil pressure sending until,engine temperature sending unit,ignition coil and distributor). Are there any websites that specialize in Ford truck ignition electrical components? I need to replace this electrical wiring harness and any help would be greatly appreciated! Thank-you!
Old 03-31-2011, 07:40 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Everyone needs to keep looking on the vendors websites that cater to these trucks to see if and when they may reproduce some of the harnesses for these trucks. As far as I know, you can't get a new original harness.
Old 03-31-2011, 07:55 PM
billt28's Avatar
billt28 billt28 is offline
billt28 is gaining momentum as a positive member of FTE.billt28 is gaining momentum as a positive member of FTE.
A junk yard would be your best bet.
Old 03-31-2011, 07:59 PM
ri_truck_guy's Avatar
ri_truck_guy ri_truck_guy is offline
ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.
What's wrong with the one you have? Generally, unless one burns they can be unwrapped and repaired....
Old 03-31-2011, 08:00 PM
Smile Thanks!
Thank-you for the quick reply! Your help is apprciated!
Old 03-31-2011, 08:17 PM
Smile Insulation rubber (plastic) weathered and cracked at base of connection terminals
I realize that these wires can be repaired. The wiring harness itself is in pretty good condition considering its 25 years old (original), but what I've noticed is that some of the insulating rubber (plastic) at the base of some of the connection terminals is cracked due to the heat and has dried out? It's very brittle. Because of the location it makes it difficult to repair. Mind you these wires are 25 years old and are not going to last forever! I was just wondering if there were any websites that specialized in aftermarket Ford truck ignition module electrical wiring harnesses? That's all? Obviously Ford factory origionals are the best,but are no longer being reproduced?
Old 03-31-2011, 08:58 PM
If you can't find another harness, there's a relatively simple way to fix the broken insulation near the plugs. Most people don't realize how easy it is to remove wires from the plugs. Alomst all are held in by nothing more than a simple tab that can be held back with a precision screwdriver while you slide the wire out. Then it's just a matter of sliding on some heat shrink tubing and hitting it with a heat gun. Again, understand you prefer to go with the new harness, but it's a really easy repair if you can't get one.
ignition control module change and re-wire rmthurman Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 06-05-2016 12:17 AM
How to Factory Tachometer 1980-1986 F-Series 82F1507.5 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 30 02-24-2016 09:25 AM
Fuel pump relay/sending unit wiring pbjosh 1968-2013 Full Size Vans 11 11-30-2014 01:17 PM
1986 F150 ignition swap millboroman 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 12-19-2011 07:43 PM
Which distributor to use for 1988 460? rhoward 1987 - 1996 F150 & Larger F-Series Trucks 5 10-11-2009 09:46 PM
Tags
1983, 1999, 351, 83, 89, bronco, electronic, f150, f250, ford, gauge, harness, ignition, ingnition, module, road, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
