Brake lights on, even when car is off. Turn signal causes light to go off if car is off. Blinks if car is on. Not brake switch. Washer doesn't work, wiper does. Pull fuse 8 & lights go out. Is it the turn switch?
The signal switch is a problem spot but I don't know about all of that. Mine is going bad but it's symptoms are: sometimes hard to keep locked on left turn, intermittent wipers sometimes don't work unless you randomly switch speeds or wiggle.
