Truck horns, which ones??? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 04-03-2011, 08:27 PM
snaponprofile's Avatar
snaponprofile snaponprofile is offline
snaponprofile is starting off with a positive reputation.
Ya, I know. I'm gonna try to get some peterbuilt horns used. I'm just looking at that system to use w/ them. I never really realized the benefits of having onboard air. Fill your own tires up, airbags, horns, nail guns, etc.
  #32
Old 04-03-2011, 08:47 PM
Volvo92906's Avatar
Volvo92906 Volvo92906 is offline
Volvo92906 is gaining momentum as a positive member of FTE.Volvo92906 is gaining momentum as a positive member of FTE.
If you get horns from a Pete you will need a valve. You may find horns for sale with the valve on them already, it is integrated. First off, theyre junk, second you will need to get a remote location valve. Hornblasters Air Horn Products Catalog! Find The Perfect Train Air Horn For Your Car Or Truck! this one is fine. And it it quits working, it isnt integrated into your horns.
  #33
Old 04-03-2011, 08:48 PM
Thanks, I thought you said to go 3/8 to the horns though? Is 1/4 suitable?
  #34
Old 04-03-2011, 08:53 PM
Volvo92906's Avatar
Yeah, I was thinking 1/4" was too small but I was wrong... 1/4'' is whats on my truck (I couldnt look because its in a different city due to high fuel prices im driving a car). But the 1/4 will work fine. As the others said, bigger line means more volume which means more sound but big rigs only use 1/4 going to their horns.
  #35
Old 04-03-2011, 08:55 PM
Oh ok, good thing I won't have to order extra line, thanks.
  #36
Old 04-03-2011, 09:01 PM
Volvo92906's Avatar
Last thing ill leave you with... Be forewarned about hornblasters air line. It IS NOT the same stuff I was talking about. When I ordered my stuff (compressor, valve, pressure switch) I decided "Hey, ill get the line from them cause im getting everything else from them" but that was a bad idea.
I use the compression fittings the trucks use as well and when I used their line everything leaked. They have the newer push in design that may be better but I dont know for sure. Their line is a bit cheaper than what I expected. Try it cause youre getting it with the kit anyhow. Just a heads up.
It sounds negative but I really do like hornblasters. If I could change some things with them I definitely would but they are good people and have a pretty good, reliable company.
  #37
Old 04-03-2011, 10:30 PM
onlya4.9's Avatar
onlya4.9 onlya4.9 is offline
onlya4.9 is starting off with a positive reputation.
i had a big air horn that i pulled off our freightliner and put it behind my grill and ran it to a direct drive air compressor, and it was pretty loud.
  #38
Old 04-04-2011, 02:38 PM
One last question, what horns sound better(deeper)? The rectangular opening with the plate in front or the round open opening? The only ones I see around here are the rectangular ones, do they sound the best?
This a good deal?, looks like it has the solenoid already attached. If its good and this style sounds good, I'll ****** her up. - http://cgi.ebay.com/ebaymotors/CLEAR...ht_1646wt_1007
  #39
Old 04-04-2011, 07:34 PM
  #40
Old 04-04-2011, 07:58 PM
L. Ward's Avatar
L. Ward L. Ward is offline
L. Ward has a good reputation on FTE.L. Ward has a good reputation on FTE.
Quote:
Originally Posted by snaponprofile View Post
If its off an old firetruck, that should be a Grover "Stuttertone". If it is, you would be very pleased with it, not only are they loud, but they have a very distinctive tone.
YouTube - Grover 1510 Air Horn
  #41
Old 04-05-2011, 11:47 AM
Actually, I'm not crazy about how that sounds, I like the big rig sound better, thanks for the video though. Doesn't this horn seem a bit under priced? I wonder why??
**CLEARANCE** TRAIN AIR HORN KIT SEMI TRUMPET BLOWOUT - eBay (item 290548528192 end time Apr-22-11 00:54:37 PDT)
  #42
Old 04-05-2011, 07:40 PM
L. Ward's Avatar
Actually that one is not too badly priced, as I do not think it is a Grover, but is a knock-off brand. If you look at the bottom of it, it has the solenoid on it already. A true horn from a semi would not have that. The key for the tones on a semi horn is in the diaphragm and the size/length of the trumpet. A bigger diaphragm with a longer/bigger trumpet opening will have a lower tone, at the same time it will also need more air to get the same sound levels (not tone) as one with a smaller/shorter trumpet.
  #43
Old 04-05-2011, 08:27 PM
So you are saying the one I posted would sound similar to a big rig or higher toned? I emailed the guy and he said its a reproduction horn and he got a bunch at a auction. He said they were made a year ago and were never really on a truck but that they sounded good and worked well. Stay away???
  #44
Old 04-05-2011, 08:29 PM
L. Ward's Avatar
At the price he has listed, its not a bad deal.
  #45
Old 04-05-2011, 08:32 PM
That what I thought, and no junkyard around has big rig parts. I think I might just bite, thanks. He also said it takes a 3/8 line, seems abnormal.
Onboard air, airbags, horns - complete KG6EPF 6.7L Power Stroke Diesel 75 04-14-2015 11:23 AM
Changing out horns Daren1093251 2004 - 2008 F150 4 03-09-2015 05:18 PM
Semi Truck Air Horn A/Ox4 1999 to 2016 Super Duty 10 12-29-2011 11:52 AM
air horn pics!! Gobstopper909 1994.5 - 1997 7.3L Power Stroke Diesel 18 10-24-2008 07:35 AM
Big Rig Air Horns 89Bronco_EddieBauer 1978 - 1996 Big Bronco 5 09-05-2004 01:13 AM
Tags
0407, 60, f250, ford, grill, horn, horns, install, junkyard, pasiren, semi, siren, sounding, speaker, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
