Truck horns, which ones??? - Page 2 - Ford Truck Enthusiasts Forums
Old 04-02-2011, 06:53 PM
snaponprofile's Avatar
snaponprofile snaponprofile is offline
snaponprofile is starting off with a positive reputation.
Quote:
Originally Posted by L. Ward View Post
Semi's use pumps that are gear driven and attached directly to the motor. Some smaller class straight trucks use belt driven compressors. If you want an engine driven one, the best bet would be to go with something like this --> Project Jeep CJ-7 - Onboard Air System York AC Compressor Conversion
Ya, imnot going that route, just gonna run it off a normal one, thanks.
Old 04-02-2011, 06:56 PM
L. Ward's Avatar
L. Ward L. Ward is offline
L. Ward has a good reputation on FTE.L. Ward has a good reputation on FTE.
Thats not a bad looking kit, seems pretty complete.
Old 04-02-2011, 07:08 PM
Volvo92906's Avatar
Volvo92906 Volvo92906 is offline
Volvo92906 is gaining momentum as a positive member of FTE.Volvo92906 is gaining momentum as a positive member of FTE.
Yeah, hornblasters has some good stuff.
Just because you brought up compressors I will bring this up.... Using your A/C compressor plumbed into your air tank would work fine. Just put a toggle switch on it to turn it on and off. Its belt driven and pumps air. I did it for a while but since its a 22 year old compressor it seized up eventually and I got a 100% duty cycle compressor from hornblasters. I have a tank off a semi which means its pretty big (im not sure how to determine the volume?) but I need to get a second compressor to make it perfect. If you stick with a smaller 2 gallon tank or so you will be in great shape.
And as they said, trumpets are cheaper at a truck junkyard. Get the compressor from HB and even the tank, look elsewhere for a horn(s). They do have some for sale but I think theyre kinda pricey and I cant vouch for them personally.
Old 04-02-2011, 07:38 PM
Ok, I'm really liking that kit, only thing is it doesn't say what size hose they include? I guess thats trivial anyways since I can just buy some bigger hose w/ different fittings.
Is there a way I can wire my horn up to the steering wheel button? If I do that, I'll just put a switch on my dash to change it from the regular horn to the air horn but both activated by the horn button. It just instinct to push that and when I need the horn most, I'll push the horn instead of hitting a switch so I'd rather have the air horns hooked up to my steering wheel. That possible?
Old 04-02-2011, 07:59 PM
Volvo92906's Avatar
Yup, its possible. I did it because I eventually wired my air horn into my aftermarket car alarm so since I had the electric switch anyhow I wired it that way.
Relay under hood to OEM horn wires, use a toggle to switch between 87 (factory) and 87a (air). (I assume you understand how a relay works? no offense.)
Old 04-02-2011, 08:03 PM
jv2290's Avatar
jv2290 jv2290 is offline
jv2290 is starting off with a positive reputation.
I got lucky. I found a guy who was junking a mid 90's Dodge Caravan that was handicapped equipped. It had a 12 volt air pump in it and the guy told me I could keep it for moving the van off his lot for the junk man. So if you go to a junk yard, look for a van like that. They usually have air bags in the back so they need pumps. I just haven't installed mine yet haha. That's better than those expensive pumps you gotta buy new
Old 04-02-2011, 08:09 PM
No I don't, sorry. I figured I would do it with a toggle switch, just don't exactly know how to wire it up. I'll have to get a wiring diagram (do 87 and 87a stand for the number on a wiring diagram?).
Old 04-02-2011, 08:11 PM
Quote:
Yeah, thanks. I can't look around in junkyards around here though, I have to tell them exactly what I need and why and they go and get the part. Its really annoying not to be able to go digging in a yard.
Old 04-02-2011, 08:49 PM
Volvo92906's Avatar
Quote:
Some people are a lot better at finding/giving info than myself so maybe someone can help.
But, a relay is an electrical switch. There are numbers on a relay: 85, 86, 30, 87. (87a) which is not always there but you can get relays with it. Newer relays are 1, 2, 3, 4, 5 and they work the same way.
85 (2)- Battery or ignition Power
86 (1)- Ground (switched) This makes it easier to just run a wire in to a switch and ground it instead of looping a power back to battery.
30 (3)- Battery/Fused
87 (5)- accessory (air horn)
87a (4)- accessory (OEM horn)
Basically with the relay off (86 toggle switch off) the relay is not functioning and will default to 87a. When you turn it on, the relay will activate and switch to 87 and you will have your air horn circuit.
Sorry, im having a hard time visualizing it. Im pretty sure thats right though... I havent messed with one in a while. So basically when you energize 85 and 86 electromagnetism closes the contacts between 30 and 87 (or 87a) creating a circuit. With this setup you can use low amperage to turn on the switch and it will step it up and put out higher amperage which helps save in bulkiness of wires.
Sorry if this confuses you.. You can just wire it directly or however you would do it but when you know how relays work you will never go back, haha. It keeps everything contained really well and if youre like me and really obsessive compulsive about wiring messes, theyre godly.
Old 04-02-2011, 09:25 PM
Ya I think I see what you are saying. Where do you get them, radio shack?
Old 04-02-2011, 09:34 PM
Volvo92906's Avatar
Parts store (auto zone, oreillys, advanced), walmart, kmart... Honestly you can get them about anywhere. Auto section. Theyre only a couple bucks.
Old 04-02-2011, 09:36 PM
Would I need one rated for more than 3 amps?
Toggle Switch with On/Off Label Plate - RadioShack.com
  #28
Old 04-02-2011, 09:56 PM
Volvo92906's Avatar
Thats fine to use.
  #29
Old 04-03-2011, 08:00 PM
Ok I think I'm leaning more towards this. It seems to be the same as the other kit I posted but just a 325c compressor instead of a 400c one. Would I need to purchase a electric valve or do most air horns have them on them already?
  #30
Old 04-03-2011, 08:21 PM
jv2290's Avatar
Most air horn kits already come with a valve. You'll have to ask if it has a valve or not. Usually when I see them in Jc Whitney books it's optional and a few extra dollars for the electric one. The kit you just posted I see doesn't have horns and doesn't say a valve is included. So if you don't have one, you'll need the valve. And horns obviously.
Onboard air, airbags, horns - complete KG6EPF 6.7L Power Stroke Diesel 75 04-14-2015 11:23 AM
Changing out horns Daren1093251 2004 - 2008 F150 4 03-09-2015 05:18 PM
Semi Truck Air Horn A/Ox4 1999 to 2016 Super Duty 10 12-29-2011 11:52 AM
air horn pics!! Gobstopper909 1994.5 - 1997 7.3L Power Stroke Diesel 18 10-24-2008 07:35 AM
Big Rig Air Horns 89Bronco_EddieBauer 1978 - 1996 Big Bronco 5 09-05-2004 01:13 AM
Tags
0407, 60, f250, ford, grill, horn, horns, install, junkyard, pasiren, semi, siren, sounding, speaker, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
