You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Can anyone point me towards any resources (if available) to disable/bypass the rev/speed limiter? Was surprised that it "throws out the anchor" at 100 MPH....
My 2007 cut out at 103MPH. My 2011 is similar. I'm not sure if it's a rpm limiter or speed limit (limit). Didn't have the time to look down that long to see.
Try to find a set of 44" mudder tires... the huge circumfrence will full the speed limiter into thinking you're only going 100 when its actually going 120 or so!
__________________
1997 F250HD 4wd, 460-5-speed Ext. Cab, Blue
2007 Navigator L Dark Blue Pearl
2003 Mercury Marauder, Dark Blue Pearl, Trilogy Supercharged, 13.1 @ 105
Good point! I had to put four new tires on in the fall - Michelin LTX M/S2. They were almost $1400 installed (with an aligment). Pretty good T rating on them at 118 MPH. Still nowhere near the tires I had on my old sport sedan!
Frankly, if you want to go over 100mph you might have done better to put that $1400 towards an old BMW sport sedan. While likely exhausted at this point, at least it was initially designed to hit those speeds.
Buying a 2007 BMW 750iL (what are they now, about $40,000 used?) and expecting it to tow your 8,000 lb boat, haul firewood through the woods, or carry 8 people in its 5 seats would be no less ridiculous than pushing your Expy faster.
I like speed as much as the next guy, but you need a different set of car keys.
__________________
