Wastegate solenoid - Ford Truck Enthusiasts Forums
Wastegate solenoid
Old 03-31-2011, 10:13 AM
ttttmaxx ttttmaxx is offline
ttttmaxx is starting off with a positive reputation.
Wastegate solenoid
Good morning guys,
I noticed something yesterday that I should have seen when I bought my truck last year. I was cleaning under the hood and noticed that the previous owner had the wastegate unplugged? When I bought eh truck I immediately ordered a Dptuner and now I'm wondering how this effects Jody's tunes? I assume Jody's chip needs this plugged up for whatever reasons? Im not a turbo guy so dont really understand the ins and outs of the wastegate system. Can someone help explain what the prior owner was trying to achieve by unplugging the solenoid? Maybe he determined it was not functioning correctly? Is there a way to check the solenoid? and shouldn't I hook this back up for chip purposes? What do the red and green lines actually do? Thanks for educating me on this in advance. Maxx
Old 03-31-2011, 10:26 AM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
You are probably talking about the red line to the wastegate actuator, correct? If so, this won't affect tuning and only keeps the PCM from pulling off boost early.
Old 03-31-2011, 10:30 AM
wastegate
Quote:
What Im talking about is the there is the plug on the solenoid. The electrical plug which is supposed to be plugged into this is just dangled next to it? thanks Maxx
Old 03-31-2011, 11:02 AM
wastegate
Quote:
Im trying to understand how this system works in general, so if the solenoid is unplugged does it make more or less boost? If its unplugged I assume the only thing keeping the wastegate closed is spring pressure inside the actuator? And this starts to open at around 5 to 7 psi? Seems like I definitely need it plugged in unless Im way off base with my thinking (Which I usually am). Thanks
Old 03-31-2011, 12:00 PM
JT250's Avatar
JT250 JT250 is offline
JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.
It allows it to build more boost w it unplugged. This equals more power and efficiency. In our trucks you don't need to blow off till around 25 to 28 from what I've been told. Those number will keep you running safe. You could run up to 40 w a different turbo on a truck with stock injectors. After 40 you have to introduce more fuel. Most people unplug the red line from the actuator.
Old 03-31-2011, 12:04 PM
JT250's Avatar
If it is opening too early you can tighten the arm that connects it to the exhaust housing.
Old 03-31-2011, 12:07 PM
wastegate
Quote:
Thanks Jason, Is the same result by just unplugging the red line versus unplugging the wastegate solenoids electric connection? I have been doing some searching and it appears most unplug the red line as you say, but I cant find any info on having the solenoid unplugged. Does this do the same thing? Maxx
Old 03-31-2011, 12:19 PM
JT250's Avatar
Don't know about the electrical connection. I have not ever been told to unplug it. someone else might chime in later today nd offer more insight. I wouldplug that in and unplug the red line from the wastegate and push it over the threads of on intercooler boot clamp.I can build 30 psi with the things done in my previous post.
Old 03-31-2011, 12:21 PM
cj45lc's Avatar
cj45lc cj45lc is offline
cj45lc has a great reputation on FTE.cj45lc has a great reputation on FTE.cj45lc has a great reputation on FTE.cj45lc has a great reputation on FTE.
Is the elect plug under the turbo? If it is it's for the ebv, it closes when the engine is cold for faster warm-ups.
Old 03-31-2011, 12:23 PM
No its not the ebv. This is on the front side of the solenoid at the ypipe
Aftermarket Turbo/Wastegate Solenoid valiant500hp 1999 - 2003 7.3L Power Stroke Diesel 6 06-10-2012 05:38 PM
#30 Fuse Blows at Key On sflem849 1999 - 2003 7.3L Power Stroke Diesel 17 05-19-2011 10:11 AM
Wastegate Lever Stuck, Help ASAP SNIPER168308 1999 - 2003 7.3L Power Stroke Diesel 6 03-05-2011 05:51 PM
#30 fuse keeps blowing!! Joshglov 1999 - 2003 7.3L Power Stroke Diesel 47 04-16-2010 04:20 PM
Disable the ebpv/ and the wastegate hucka1a 1999 - 2003 7.3L Power Stroke Diesel 8 05-31-2008 02:14 PM
Tags
2003, 73, drive, electric, f250, f350, ford, harpoon, liter, safe, sale, solenoid, turbo, unplugged, wastegate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
