Squeak/Squeal in 4x4
1999 F350.
I just starting getting a slight squeak/squeal on the front end of my truck in 4x4.
I can replicate the noise by locking either the hubs or transfer case alone as well. Noise goes away if both hubs and transfer case are disengaged.
Rhythmic squeal, with wheel/axle rotation.
Does this sound like needle bearings? Or possibly something else?
The needle bearings are the bearings that carry the axle through the main hub. When the hub is locked, they turn with the hub, so there is no movement. There is only movement in the needle bearings when the hub is unlocked. So I'd guess that it's not the needle bearings.
A rhythmic squeaking would suggest to me a front axle u-joint. Have you greased them lately? Is the squeak consistent or more when you're turning?
If they are original joints they have no grease fittings, and if they are squeaking they probably need to be replaced.
Turn the steering wheel all the way left or right, then jack up one wheel at a time, lock the hub, and give the wheel a spin. It should rotate easily, no binding or noise. If it binds, you found the bad joint.
Joshhighboy
04-23-2017 01:20 AM
Rob04
11-02-2006 01:46 PM
