rear leafs on front?
Received 3,090 Likes
on
on
the pins holes arent centered on the rear ones. it might work if not for that. the length along the surface is longer but its about the same pin to pin.
im just gonna bite the bullet and do it the right way....whatever that is...add-a-leaf or leveling kit? same thing?
once that happens how do i fix the camber? im not looking for a monster truck, just a level nose...
btw : d44 ttb
btw : d44 ttb
there is a shackle and it is on the front of the spring ! if you do use the whole spring pack you would need to do some fabrication for the mounts and also your TTB mounting points would need to be lowered !
now you can put a couple of individual leafs in there and then you most likely will need a set of alignment bushings that go in the upper ball joint !
78fourby4f250
05-08-2020 09:50 PM
ford19792003
11-12-2013 03:45 PM
