purchasing a F700 vin decode help please - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 03-30-2011, 10:05 PM
canyoncat canyoncat is offline
canyoncat is starting off with a positive reputation.
Need help with vin decode thanks. F70EVJ21014 is the vin. axle code E3M. I think its a 1970 with a 361
Old 04-03-2011, 10:23 AM
80broncoman 80broncoman is offline
80broncoman is gaining momentum as a positive member of FTE.
Ive been looking for mine (a 1994) and haven't found much at all.
mine is 1FDXK74C1RVAXXXXXX
I would love to find something like a copy of the window sticker or build sheet.
I'm gonna call ford tomorrow to see what i can get.
Old 04-04-2011, 06:42 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Welcome to FTE
F70 = F700.
E = 361 2V FT engine.
V = Kentucky Truck Assembly Plant.
J21014 = 1970.
E3M: E3 = Eaton model 16244 2 Speed Rear Axle / 6.50/9.04-1 / 17,500 lb. Rear Axle Capacity // M = Ford 7,000 lb. Capacity Front Axle w/P/S.
Quote:
Originally Posted by 80broncoman
1FDXK74C1RVAXXXXX
1FD = FoMoCo USA Incomplete Ford Vehicle.
X = GVWR Rating: Class 7, 26,000-33,000 lbs.
K74 = 1994 Cab Model, F700 Diesel.
C = Cummins model FD-1060 5.9L (359 cid) I-6 Diesel.
1 = Check Digit, FoMoCo use only.
R = 1994.
AXXXXX = 1994 Numerical Sequence of Assembly, the truck's specific serial number.
Old 06-12-2011, 02:35 PM
markfuga markfuga is offline
markfuga is starting off with a positive reputation.
Hi,
I'm trying to decifer the following info from the door tag but it's kinda printed out of alignment with the tag info:
VIN: 1FDFNF70H3EVA17576
Exterior paint colors 9E 87 ?? not sure Im reading that right
WB: 171
Type-GVW: F701
Body: FH8
Trans: SP
Axle: E0M
Spring: nothing printed ??
Old 06-13-2011, 07:59 AM
Please take a look at the VIN on your truck again. It has 17 digits, not 18.
I cannot decode it until I know which digit was added in error.
Old 06-13-2011, 09:04 AM
Hi Bill,
You're right, I have one too many "F's". The correct VIN is:
1FDNF70H3EVA17576
Old 06-13-2011, 09:45 AM
Quote:
Originally Posted by markfuga View Post
Hi Bill,
1FDNF70H3EVA17576
Welcome to FTE
1FD = FoMoCo USA, incomplete vehicle.
N = Class 6 ~ Gross Vehicle Weight Rating range: 19,501-26,000 lbs.
F70 = F700 (gas).
H = 370 2V or 4V (FoMoCo uses the same code for both).
3 = Check digit, FoMoCo use only.
E = 1984.
A17576 = 1984 Numerical Sequence of Assembly, the trucks specific serial number.
9E = Special White / 87 = ? 87 is not listed until 1988. Is the truck tu-toned? If not, 87 applies to something else.
171" Wheelbase.
F701 = F700 (gas), 23,100 lbs. Gross Vehicle Weight Rating.
FHB: FH = Tan all Vinyl // B = Standard Cab.
SP = Spicer Model 4054D 5 Speed Manual Transmission.
E0M:
E0 = Eaton Model 16244 Two Speed Rear Axle / 6.14/8.54-1 / 17,500 lbs. Rear Axle Capacity.
M = Ford Front Axle w/Power Steering / 7,000 lb. Front Axle Capacity.
Having the codes on the Certification Label mis-aligned is typical, makes it difficult to figure out.
Look below where it says "Spring" for two (or more) letters.
Took me awhile to decode this jazz.
Having to step over one Basset Hound to get oughtta the chair in front of the computer, then walk around the table to the microfiche viewer, then step over another to sit down in front of it, is the reason.
Old 08-14-2011, 05:51 PM
1sticky1 1sticky1 is offline
1sticky1 is starting off with a positive reputation.
how bout
F70BVFA5629
1979
thanks
Old 08-22-2011, 06:58 AM
Quote:
Originally Posted by 1sticky1 View Post
how bout
F70BVFA5629 / 1979
F70 = F700 (gas or maybe diesel).
B = (sigh) FoMoCo used the B VIN engine code in 1979 for 4 different engines.
Is it a gasser or a diesel? The only way I found out which engines were offered, was to troll thru the engine sections of the truck parts catalog for the applications
300 1V I-6 (not installed in 700 and larger series trucks) / 370 4V / Two diesels, Caterpillar V190-3208 & Cummins KTA.
FA5629 = 1979.
Old 08-22-2011, 05:39 PM
Is it a gasser or a diesel? The only way I can find out is to troll thru the engine sections of the truck parts catalog for the applications
300 1V I-6 (not installed in 700 and larger series trucks / 370 4V / Two diesels, Caterpillar V190-3208 / Cummins KTA.
FA5629 = 1979.
It's a gas engine, don't know the size......
Thanks
Old 08-22-2011, 07:15 PM
.. 370 4V ..
Old 10-08-2011, 05:28 PM
h2o tech h2o tech is offline
h2o tech is starting off with a positive reputation.
new member here. had a vin question as well. found decoder site for commercial ford trucks..
www.fleet.ford.com
Old 04-19-2014, 01:01 PM
Phased3 Phased3 is offline
Phased3 is starting off with a positive reputation.
Thanks for this.
Quote:
www.fleet.ford.com
Old 05-28-2014, 05:14 PM
ColtCCO ColtCCO is offline
ColtCCO is starting off with a positive reputation.
Bill,
If you could help me with this VIN, that would be awesome! Really need to find out what the rear axle is so we can get brakes and seals for it.
1FDNF70H3KVA31022
Thanks!
Old 05-31-2014, 05:46 AM
Quote:
Originally Posted by ColtCCO View Post
Bill, If you could help me with this VIN, that would be awesome! Really need to find out what the rear axle is so we can get brakes and seals for it.
1FDNF70H3KVA31022
Welcome to FTE
AXLE code not listed in VIN, listed separately (printed) on the Certification Label.
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
N = Class 6 (Hydraulic Brakes): 19,501-26,000 lbs. GVWR
F70 = F700 (gas).
H = 370 2V or 4V
3 = Check Digit - FoMoCo use only.
K = 1989.
A31022 = 1989 Numerical Sequence of Assembly, the trucks specific serial number.
Vin decoder Will237 1947 and Older Ford Trucks 7 04-04-2016 01:35 PM
vin decode frty7ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 02-17-2016 01:50 PM
Vin decode 1974 F 900 sspencer Large Truck 6 06-14-2015 11:36 AM
1967 F600 VIN DECODE Ross Carl 1967 - 1972 F-100 & Larger F-Series Trucks 1 04-24-2015 07:44 PM
1963 Unibody Vin Decode Qmc08 1961 - 1963 F100 Unibody 1 05-25-2014 09:45 PM
Tags
1977, 1986, 2011, assembly, build, chart, decode, decoding, expeditions, f700, ford, kentucky, number, sequence, sheet, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
