1987 F800 8.2 Passenger Side Canister
The following users liked this post:
Luberfiner secondary oil filter, we used them on semi's years ago
Should be a drain plug on the bottom and you undo the strap clamp to get the cap off to access the filter
We quit using them years ago because they were messy, required another gallon or 2 of oil plus the cost of a second filter
I'd find where the lines connect to the engine, then remove them and plug the fittings
The following 3 users liked this post by Destroked 450:
fordtruckman
Michigan Chapter
11-10-2012 11:39 PM
