purchasing a F700 vin decode help please
05-31-2014, 10:20 AM
on
Quote:
Originally Posted by
NumberDummy
Welcome to FTE
AXLE code not listed in VIN, listed separately (printed) on the Certification Label.
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
N = Class 6 (Hydraulic Brakes): 19,501-26,000 lbs. GVWR
F70 = F700 (gas).
H = 370 2V or 4V
3 = Check Digit - FoMoCo use only.
K = 1989.
V = Kentucky Truck Assembly Plant.
A31022 = 1989 Numerical Sequence of Assembly, the trucks specific serial number.
Thanks a bunch! I believe the axle code is "W3M". Any idea what that means?
05-31-2014, 02:07 PM
ColtCCO
Thanks a bunch! I believe the axle code is: W3M
W3M:
W3 = Rockwell model RS-17-220 Two Speed Rear Axle / 6.14/8.57 / 17,500 lbs. Capacity.
M = 7,000 lbs. Capacity Ford Front Axle with Power Steering.
05-11-2017, 02:50 PM
on
Ok, not new to the Site but this seems to be the Medium duty vin decode thread, what would a
F
D
X
J74
O/0
H
V
A57447
be? Thanks in advance.
05-11-2017, 04:57 PM
watongaokie
Ok, not new to the site but this seems to be the Medium Duty VIN decode site.
1FDXJ74O0HVA57447
X = Class 7 - Air Brakes - 26,001-33,000 lbs. Gross Vehicle Weight Rating.
J74 = B700 Diesel (B = School Bus).
O =
This is the engine code, but there's no letter O or a zero.
0 = Check digit, FoMoCo use only (I've never seen a zero used for a check digit).
H = 1987.
A57447 = 1987 Numerical Sequence of Assembly, the trucks specific serial number.
05-15-2017, 09:53 AM
on
VIN decode
I need help with a VIN on my old ford truck F85P9433923. Any help would be appreciated.
05-17-2017, 12:17 PM
lmort
I need help with a VIN on my old ford truck F85P94 33923. Any help would be appreciated.
It's a 1959 F850 w/a 401 4V
I decoded this VIN in your other post, but...as I said before, the 6th digit (decodes to the assembly plant) is a letter, not a number.
05-19-2017, 12:00 AM
on
Can you decode this
F81FUE90712
212 F810 D281 2FBE
3000 199 3800 721076
Reason: Wrong thread
05-27-2017, 10:36 AM
M00S
Can you decode this?
F81FUE90712 / WB: 212 / COLOR: Blank* / MODEL: F810 / BODY: D281 / TRANS: 2 / AXLE: FBE / MAX GVW LBS: 30000 / CERT NET HP: 199 / RPM: 3800 / DSO: 721076
F81 = F800 (gas).
F = 391 4V FT engine.
U = Louisville KY Assembly Plant.
E90712 = 1969.
212" Wheelbase.
F810 = F800 (gas), 30,000 lbs. GVWR
D281: D2 = Charcoal Black Corinthian Vinyl & Charcoal Black Lariat Pattern Woven Plastic / 81 = 81B Custom Cab.
2 = Clark model 282V 5 Speed Direct.
FBE:
FB = Eaton model 18221 Two Speed Rear Axle / 6.50/8.87 / 22,000 lbs. Rear Axle Capacity.
E = Ford Rockwell Timken 9,000 lbs. Capacity Front Axle.
30,000 lbs. Gross Vehicle Weight Rating.
199 net HP @ 3,800 RPM
721076: 72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
1076 = Domestic Special Order Number, truck special ordered by the original purchaser, not "bought off the lot."
* This referred to the non standard paint color, why there is no COLOR code stamped on the Warranty Plate.
09-26-2017, 01:34 AM
on
I like big trucks and I can not lie
12-03-2017, 04:21 PM
on
what about this one?
12-03-2017, 08:16 PM
Gary38532
Decoded a coupla minutes ago in your other thread.
01-04-2020, 10:53 PM
on
One more vin for you?
Hey numberdummy i got one for you if you wouldnt mind helping me out. I know its a 79 LN702, 370 5/2 speed. Not able to find any info on the N’s but I hope for trans and rear end specs. Thanks in advance.
02-05-2020, 02:00 PM
on
If you could decode one for me, this is on an 88 F700 I'm looking to buy.
1FDPF70H5JVA37685
Thanks!
02-10-2020, 10:22 AM
adventure-west
Post a larger picture, I cannot read this puppy and it cannot be enlarged.
02-10-2020, 10:31 AM
mrstang01
1FDPF70H5JVA37685
P = Class 7 Hydraulic Brakes, 26,001-33,000 lbs. Gross Vehicle Weight Rating range.
F70 = F700 (gas).
H = 370 2V or 4V (6.1L).
5 = Check digit, FoMoCo use only.
J = 1988.
A37685 = 1988 Numerical Sequence of Assembly, the trucks specific serial number.
