Ignition rod
Ignition rod
91 in my sig.
Went to start it yesterday, key turned freely and then power wont go off. So I went out and bought a cylinder and switch. Put the cylinder in, same. Got the steering column down and was gonna swap out the switch but noticed the rod that actuates the switch was loose on the cylinder side.
How do I get re-attach it/see if its broke? Doesn't seem like there's anyway to get up there.
https://www.ford-trucks.com/forums/8...-actuator.html Have a look at the post by jas88 in the thread in this link. It is a very good writeup on fitting a new actuator. And it is a major PITA.
Yes, when you have the wheel off the turn signal switch is looking at you, probably one of the little plastic bits is broken.
Action410
01-18-2013 07:40 PM
rc1099
09-03-2009 12:11 AM
buffalobob
08-15-2005 04:28 PM
89Bronco_EddieBauer
Electrical Systems/Wiring
01-03-2004 03:41 PM
