E150 Transmission questions - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 03-30-2011, 08:11 PM
Jim Van Streader Jim Van Streader is offline
Jim Van Streader is starting off with a positive reputation.
First of all, there are 17 bolts on the pan of my transmission on my 93 e150. The transmission code on the door tag is G. From all my research, the 17 bolts means it can only be a C6. And, if it's a C6 it only has 3 gears. So here's the thing. Mine has 4. My problem is it's not going into 4th after I ran out of fluid on a trip. I had the filter and fluid changed, MerconV, and it would shift into 4th until it got hot, about 45 mins driving and then only go up to 3rd which makes it rev quite high past 55mph. Now it's not going into 4th at all, cold or hot.
Now I've counted the gears numerous times and there are absolutely 4. The first 3 feel like normal gear shifts and the 4th feels like an overdrive as it kicks in normally between 55 and 60 and you just hear a slow drop in engine speed and it starts going faster without pressing more on the gas. Well, that's what it used to do anyway.
My problem is what the heck kind of transmission do I have in the first place? I can't get anyone to help me because they just say oh it's s 3 speed. But that's simply not the case. Help me in my twilight zone delima.
Thank you for any and all input.
Old 03-30-2011, 10:26 PM
Henry10s's Avatar
Henry10s Henry10s is offline
Henry10s is starting off with a positive reputation.
Your 93 came with the E4OD, not C6. You must have the push-button / light at the end of the shifter, no?
Old 03-31-2011, 12:44 PM
No, no button or anything regarding it having an overdirve. Steering colum shifter only has 1 2 D. It's wierd. Plus the 17 bolt pan would not allow it to be the E40D from what I've reseasrched. That has 20 bolts on the pan.
Old 03-31-2011, 12:58 PM
Henry10s's Avatar
If that's the case, are you confusing TC lock-up as the overdrive? 20-bolts for e4od? That does not sound right...
Which engine do you have?
Old 03-31-2011, 01:10 PM
Then engine is a V6, I believe 4.9L. TC, does that stand for Torque Converter lock-up. I don't know what that is but does it have a similar effect to over drive?
Old 03-31-2011, 01:13 PM
Henry10s's Avatar
Quote:
Sort of, yes.
Old 03-31-2011, 01:19 PM
So my problem may be with my torque converter is what you're saying? That would explain the symtoms. Would that cause it to rev high at 55mph+?
Old 03-31-2011, 01:37 PM
Henry10s's Avatar
TC lock-up is supposed to do exactly what you described:
Since you ran it without fluid, I would guess that the clutches got burnt.
Next step would be to take the van to a reputable transm shop. They will take pressure readings from the Transm and come-up with a diagnosis (about $ 100). Most likely they will tell you "tranny is toast; it needs re-building".
Before you commit to that, take a print-out of their pressure readings and post them here again.
Old 03-31-2011, 01:52 PM
I was afraid of that. Funds are at all time low so a rebuild is not vialble. It would cost more than I paid for the van. I'll get it checked to make sure and post the readings.
Thanks for all your help
Old 03-31-2011, 02:06 PM
Henry10s's Avatar
C6 was built and perfected by Ford for three decades. It took Ford another decade to develop it into the 4R100. E4OD was that decade-long transition.
C6 are not as picky as their successors. You might be able to swap another one in. 4.9 + C6 is a very nice combination, desirable to many. Go to car-part.com. You might be able to get a used unit for $ 200-250.
Old 03-31-2011, 03:20 PM
Thanks Henry. I will give that a try, I can swing a few hundred. Thanks for solving the mystery, torgue converter not locking up fully explains it.
Will report back in a few days.
Jim
Old 03-31-2011, 04:09 PM
Henry10s's Avatar
If you can't DIY, many shops can swap transm for $ 350-400.
But first, I would flush the fluid one last time, though.
Old 04-01-2011, 04:14 AM
maples01's Avatar
maples01 maples01 is offline
maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.
Rebuilding a C-6 is cheaper than an overdrive transmission, get it rebuilt, a friend has 340,000 on his 95 E-150 300 I-6, and C-6, neither have been rebuilt, and I know this to be true. This is the best setup for longevity Ford ever designed, with the old twin I-beam arrangement they would go on for years with simple maintenance, I would love to have his van even now as it is.
E4OD not shifting into 3rd or 4th. AWSHUX 1987 - 1996 F150 & Larger F-Series Trucks 1 04-15-2015 06:01 PM
E4OD shifts hard -fixed- Prototypemech Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 12-24-2013 11:05 PM
Help needed with NP435 issue RJK671 1973 - 1979 F-100 & Larger F-Series Trucks 8 11-08-2013 06:32 PM
5R55E 97 RANGER-no 4th/5th gear when hot Bill0001-97Ranger Ranger & B-Series 8 07-18-2013 08:29 PM
transmission question smurf91 1978 - 1996 Big Bronco 23 07-07-2012 01:06 AM
Tags
150, 1995, 1996, 1997, 2000, 2007, 58, 97, e150, f350, filter, fit, fluid, service, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
