Fuel Pump Relay on 1989 F150 - Ford Truck Enthusiasts Forums
Old 03-30-2011, 07:56 PM
Thunderbird Mike Thunderbird Mike is offline
Thunderbird Mike is starting off with a positive reputation.
Hi,
Just bought an '89 F150 with a 4.9 automatic. The previous owner told me it needs a fuel pump relay. Can anyone tell me where it is located? I found a block with wiring running to it behind the breather in the driver's side fender wheel well. Is this is it, and if so, how do I access it? If not, I would surely appreciate someone letting me know!
Thanks!
Old 03-30-2011, 08:24 PM
tdcarter72's Avatar
tdcarter72 tdcarter72 is offline
tdcarter72 is starting off with a positive reputation.
On the 5.0L the Fuel Pump Relay is located under the plastic shield at the air cleaner support bracket.
I am not sure if the 4.9 is in the same location or not, but it might be.
Hope this helps.
Old 03-30-2011, 10:18 PM
Thanks, I'm sure it will!
Old 03-30-2011, 11:13 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Check out this thread: http://www.ford-trucks.com/forums/88...ump-relay.html Post #6 Our friend subford has some info and pics.
Old 03-31-2011, 07:30 AM
Thank you! This confirms what I thought. Now I just have to figure out how to access it. Does the relay just unplug? Thanks again!
Old 03-31-2011, 09:03 AM
rla2005's Avatar
It is a tight fit, but yes the relays just plug in. I find they are tough to remove. Maybe someone else has a "trick" to getting them unplugged a little easier?
Old 03-31-2011, 01:25 PM
Thanks for all your help!
Old 03-31-2011, 02:53 PM
rla2005's Avatar
Welcome to FTE
Old 03-06-2012, 06:27 PM
j1msevier j1msevier is offline
j1msevier is starting off with a positive reputation.
Fuel relay swi
It is behind the air cleaner under a black holder and it is the green one (if it is not after market) and the easiest way I have found to pull them out is with a small flat head screw driver or a flat feeler gauge slid up the side of the relay. Facing the vehicle the clip should be on the right side and they are not easy to pull out.
Old 03-06-2012, 07:39 PM
rla2005's Avatar
Thanks for the info, but this thread is almost 12 months old.
Old 03-07-2012, 08:07 AM
Thanks for all the info. You will all be happy to know that I have successfully replaced the relay. Thanks again!
1986 f150 electrical fuel pump problem dakota-boy Electrical Systems/Wiring 10 03-14-2016 10:29 AM
2000 F250SD Fuel Pump relay location nomad27 Modular V10 (6.8l) 19 12-31-2015 04:54 PM
1994 F-150 Fuel issues! Bierisch 1987 - 1996 F150 & Larger F-Series Trucks 4 02-26-2014 08:03 AM
Fuel Pump Relay for 2001 f150 Shut_It_Down 1997 - 2003 F150 7 05-27-2012 05:46 AM
2002 F250 Fuel Pump Relay docergo 1999 to 2016 Super Duty 1 08-29-2009 03:42 PM
Tags
1986, 1987, 1989, 1996, 50, diagram, digram, f150, ford, fuel, fuse, jump, location, pump, relay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
