Are there original Ford towing papers
Hi,
Because of Dutch legislation I am looking for some papers in which the maximum towing capacity of a 73 F250 2WD 8100 GVW are mentioned. Did Ford ever produce such papers or is this just not availble. I would like to put a trailer behind my truck, but before it is legal (because of insurance etc.) I need to show how much the towing capacity according to factory specifications is.
Thanks,
Bart
Thanks,
Bart
The OP is looking for the official Gross Combined Vehicle Weight Rating, GCVWR.
The original owner manual for my 1973 F250 shows the max weight of 5000-6500 lbs for a vehicle with a GVWR of 7500 lbs. I see no mention of the 8100 lb GVWR for the F250. But, this owner manual does not seem to cover all models. It shows the 360 engine for all F250s but mine is a Camper Special and has the 390. I'll try to scan and post what my owner manual says..........No luck scanning it.
GVWR doesn't tell you towing capacity. I've seen people on this forum refer to that several times when people ask about towing capacity. If you could only tow the difference between truck weight and GVWR a new super duty would only be able to tow like 1,000Lbs.
I have the paperwork from a 73 f-250 camper special, and in the trailer towing recomendations for the 4x2 F-250 with a class 4 towing acc. heavy trailer towing package 5,000 to 6,500 lbs.. I could scan this and send it to you but I don't know how to post pics on here.. Or if neccessary I could maybe send them to you as I do not need them at all..
thanks for the information, it appears that there is some kind of info out there.
wdfp, if you could email me what you have that would really help, you can send it to
rob.7@live.nl
Thanks in advance,
Bart
rob.7@live.nl
Thanks in advance,
Bart
mbutts
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
17
11-09-2011 11:05 AM
fasthufi
11-24-2009 02:36 PM
Kenworth
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-13-2003 01:50 PM
