1997 f150 fuel pump problem - Ford Truck Enthusiasts Forums
Old 03-30-2011, 01:11 PM
rmperrin rmperrin is offline
rmperrin is starting off with a positive reputation.
We are having a problem with our 1997 F150. We replaced the fuel pump, but it still turns over but won't fire. When we turn over the engine, a little bit of fues comes out at the filter, but not much. There is spark, so it can't be the electrical system, and was wondering what we could check to see what else could be wrong. (I'm the computer friendly wife and not the repairer, so please be patient!!)
Old 03-30-2011, 07:24 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
When going from key off to key on, the fuel pump is supposed to run to 1 to 2 seconds. Listen for the whirring sound during this time to see if the pump's motor is running. If it is, then either the pump is faulty or there is a clog or restriction in the pickup or the fuel line.
If the pump's motor never runs, then it's likely there wasn't anything wrong with the original pump and it's likely that the pump simply is not getting power when it's supposed to run. Check the inertia switch (see owner's manual) first to see if it has tripped.
Pump not drawing fuel Teal77F250 Fuel Injection, Carburetion & Fuel System 2 01-09-2017 10:57 AM
97 F 350, 351 Fuel pump/pumps keep running. No start. TheSmanman 1987 - 1996 F150 & Larger F-Series Trucks 11 12-12-2015 03:30 PM
it happen again....more question RadioControlGuy85 1987 - 1996 F150 & Larger F-Series Trucks 0 12-11-2015 01:00 PM
1997 Ford E150 5.4L randomly shuts off? anon1028 1968-2013 Full Size Vans 9 01-12-2015 05:18 PM
No Power to Fuel Pump Charles in Oregon 1987 - 1996 F150 & Larger F-Series Trucks 6 03-10-2013 08:43 PM
Tags
150, 1996, 1997, 98, explorer, f150, filter, ford, fuel, memphistn, problem, problems, pump, pumps, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
