Typical DEF Usage Chart
Old 03-30-2011, 08:46 AM
pbruckne's Avatar
pbruckne
pbruckne is offline
Thought the forum would like to see this chart which provides "typical" DEF (diesel exhaust fluid) usage across several different build combinations (axle ratio, etc.).
-Paul
File Type: pdf
Old 03-30-2011, 08:50 AM
rickatic's Avatar
rickatic
rickatic is offline
great stuff...thanks for the many contributions that are so helpful.
Old 03-30-2011, 09:16 AM
Sgt93's Avatar
Sgt93
Sgt93 is offline
Very interesting. Thanks for posting
Old 03-30-2011, 09:19 AM
Tom's Avatar
Tom
Tom is offline
Great info, Paul! I will add this to the tech folder under your oil filter file when I get home, I'm technically supposed to be working right now...
Old 03-30-2011, 09:23 AM
kper05's Avatar
kper05
kper05 is offline
Thx Paul.
I seem to fall within the high side of the gray area for the 3.31.
Not that this has anything to do with DEF but I measured 420 degrees F at the tips during a high idle "regen" the other day.
Not as hot as I expected.
Old 06-21-2011, 06:03 PM
dschuffert's Avatar
dschuffert
dschuffert is offline
Great info, thanks for posting!
Old 06-24-2011, 11:38 PM
cirrus365's Avatar
cirrus365
cirrus365 is offline
ttt
I had to put in DEF at around 3600 miles.
50% towing
Old 06-24-2011, 11:57 PM
cummins cowboy's Avatar
cummins cowboy
cummins cowboy is offline
my truck has 13000 miles I have needed 2 DEF fills plus 2 gallons, so what is that 12 gallons of DEF??
Old 06-25-2011, 09:03 PM
sledhead_24_7's Avatar
sledhead_24_7
sledhead_24_7 is offline
Nice to see.
Mine has had 2 fill ups from the 800 mile to empty warning.
First was at 6500 miles last October / November.
Second was today 6-25-11 at 18550 miles, so not to bad in my mind 12050 miles on the first fill up.
Although I will say I think that the DEF spent most of the winter frozen, which probably helped on the mileage. Plus at $20 for 2, 2 1/2 gallons jugs I am not going to complain.
Old 06-25-2011, 09:53 PM
FourOneTons's Avatar
FourOneTons
FourOneTons is offline
19,200 miles, 3.55 axle. Not much towing, but a lot of relatively steep grades with moderate to heavy loads in the truck. I've probably got a fairly light foot on the throttle compared to many of you, but not grandpa-style with the turn signal flashing continuously....
I've never let the DEF drop very far below the half-full notice. I've added 8 gallons of DEF myself. Dealer service has probably added another 5 or 6 gallons at most.
Guessing the tank is probably a little above half right now, so roughly 15 or 16 gallons in 19,200 miles.
Joe
Javi1
6.7L Power Stroke Diesel
81
05-29-2019 12:21 PM
HRTKD
07-05-2017 08:10 AM
BII Plow Truck
2017+ Super Duty
15
03-02-2017 10:35 PM
brother steve
21
06-11-2016 10:17 AM
gwg42
03-19-2016 01:14 AM
Quick Reply: Typical DEF Usage Chart
