Cupholder Replacement
yea i had to have mine changed when i bought my truck and it was around $80 bucks, I didnt have to pay it since the dealer fixed it for me at no extra charge. You get the ashtray ( or change holder) with it as well.
Easy fix...the factory spring (single length of bent spring steel) attached to back of cupholder/ashtray has fallen off, remove the unit (pull out, then push up stop tab above it to release)...you'll find the spring (not a coil) down on floor in opening...drill two small tap holes in back of cupholder unit where it was once held on by plastic pins, re-attach spring with two small screws...done.
cup holder
well after you start to know what has to be done you will wonder why you didnt go to home depot to just buy a ****, drill a hole and mount it directly in place of replacing the assembly. with mine and i am a dealer tech, is dissambly of the dash frontal area, you will use a torx driver with bits ALOT!!!also dont forget the 8 mm socket. good luck
I am on my third one. All from a salvage yard...like 10.00 bucks for the whole thing. I always break the little plastic tabs that stop it from falling out and also lock it in an open position. I broke this one also, but this time I took a small piece of metal and bent it 90*. Drilled a small hole in it and in the plastic, took a small bolt and nut and bolted it on. Small dab of grease on it, and it works great. These thing are so fragile that one little bump from the side breaks the tab(s).
RE: Help with 2004 F150 ashtray
