Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 03-29-2011, 06:39 PM
expy4life expy4life is offline
Garage is empty, add now
expy4life is starting off with a positive reputation.
2001 Ford Lightening won't idle after mods..HELP ( race coming up)>>>
Mods that I've made... The Truck will start without mass connected..With mass connected it will start and backfire ( if throttle is held open)and there is this pinging noise also.
Injectors..60lbs
Boost 20-25lb
Ported heads trick flow
3.4 whipple charger
Headers ( no cats)
2 fuel pumps ( 255 LPH)
Adjustable Fuel Pressure Regulators
Single Blade Throttle Body (big mouth)
SCT BA 3000 ( MASS AIRFLOW)
Lobe Separation 114...
Above are the mods that my cuz in the islands has done to his lightening..Now Truck starts but it won't idle... The truck is in the islands and its build for racing..
Could it be the computer???? Ideas needed as soon as possible cause major race is coming up..
Thanks
  #2 (permalink)
Old 03-30-2011, 09:05 AM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
I probably shouldn't even ask this ,but, It dose have a good tune?
Could be a vacuum leak or the IAC might need to be cleaned or replaced.
__________________
( Phil )2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams.
L-conversion/Kenne Bell upgrade blower at 16PSI/BTS,4R100 tranny/100 shot nitrous.
594HP/620TQ Without the Nitrous 1.68 60' time/11.76 @ 116.17 with the 100 shot.
Join the the Delaware Chapter, HERE
  #3 (permalink)
Old 03-30-2011, 08:54 PM
patrickke's Avatar
patrickke patrickke is offline
patrickke is starting off with a positive reputation.
I think its in the tune as well, was your tune set up for these mods?
__________________
-04 F250 XL Diesel... Build In PROGRESS!!!
getting some things done to it !!*RiffRaff I/C BootsAlong with alot of other things from Clay
-08 4x4 ranger.. *3" Superlift, *Superchips, *33's, *intake mod, *magnaflow muffler, *full kenwood system
  #4 (permalink)
Old 03-31-2011, 01:12 AM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
+1. Who did the custon tunes? Why doesn't he make tuning adjustments?
Stewart
PS - Lightning, not Lightening.
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #5 (permalink)
Old 03-31-2011, 05:37 PM
Any more ideas..It was tune to mods 3x and it still has problems.. It has no codes..
Anymore ideas.. what kind of mass should I use with this mods?
  #6 (permalink)
Old 03-31-2011, 06:24 PM
phil6608's Avatar
You said you have the SCT BA3000 correct?
That should be fine if your tuning is right.
__________________
  #7 (permalink)
Old 03-31-2011, 08:16 PM
patrickke's Avatar
I would try someone Else's tuning contact Mike at 5Star tuning they can get you fixed up I'm sure
__________________
  #8 (permalink)
Old 04-06-2011, 03:46 AM
STOFFERJ STOFFERJ is offline
STOFFERJ is starting off with a positive reputation.
another vote for the tune being the issue
  #9 (permalink)
Old 05-03-2011, 09:03 PM
Merledude Merledude is offline
Merledude is starting off with a positive reputation.
Hi I really hope you have gotten your problem fixwd by now! would love to hear what the solution was. on the other hand I haven't read that any1 mentioned calibrating the Mass Air? def sounds like its lean if its pinging so I'd also lean towards a tuning issue.... sorry for the broken record, it also could have something to do with the Cats and EGR delete if thats been done....Good luck! Merle
Tags
01, 2001, 352, back, coming, expedition, ford, fuel, idle, lightning, mods, pressure, rev, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
