93 Ranger Trouble Codes
Hello Everyone,
My friend owns a 93 Ranger with the 2.3L Dual Plug Ignition. Recently he has been getting a Check Engine Light, however he has experienced no drivability problems. We checked his codes and they were 223, & 334.
Does anyone know if only one problem could be giving us both codes? Also what may be a few of the likely problems contributing to these codes?
Thank You in advance for any assistance that you may have for us.
Gary
Gary
Hello Marvoles, and Truck Enthusiasts,
Ford code 334 (Exhaust gas recirculation valve position sensor closed voltage higher than expected)
Well, I wish that I could tell you some news about this and how my friends 2 codes went away along with the drivability problem but I'm not sure.
Here is a quick bit of info on what may have resolved his problem.
I brought my 90 ranger to work so that we could swap Ignition Modules
"EEC IV" I think, with a Distributorless Ignition Module.
His truck was in the parking lot with a Dead Battery, and my truck was already in the garage waiting for his to be brought in.
We took the battery from my truck, placed it into his and brought his truck into the garage.
We swapped Ignition Modules and his truck would not start, then we put his module into my truck and it would not start either (now I'm scared that we damaged both modules).
"When all else fails put things back as you found them". Well I thought that I would place all 4 Ignition Module screws back into place since I was only using 2 of 4 screws on my module in his truck, and 2 of 4 screws on his module in my truck.
Guess what, It worked, both trucks would work when my battery was placed into either one (remember his battery was dead).
My friend took a short drive and had no problems and no more codes.
Anyhow it appears as though maybe, the poor connection made by the Ignition Module screws (which were slightly corroded) was causing a poor ground for the module (We are really not sure).
Before placing his module back into his truck, I cleaned all Ignition Ground connections as well as the screws. Remember to use some Heat Sink Compound between the Module and where it attaches to the manifold.
I hope that this may resolve some problems out there, maybe not your problem, but this possible fix cost no money and not much time.
I wish that I could be more help
Take Care All
Gary
Take Care All
Gary
Sailor'sGirl93
1983 - 2012 Ranger & B-Series
06-20-2013 04:30 PM
Beast12
07-15-2003 08:42 AM
