Buzzing PCV Valve - Ford Truck Enthusiasts Forums
Buzzing PCV Valve
Old 03-29-2011, 06:04 PM
krazeyelf's Avatar
krazeyelf krazeyelf is offline
krazeyelf is starting off with a positive reputation.
Buzzing PCV Valve
Hello again folks! I have a rather puzzling issue going on here with my '81 F100 300/6. I've had this noise I thought was a vacuum leak from under the dash or engine compartment, or worse yet, some type of bearing going out. A couple weekends ago, I was investigating and I saw a cracked vacuum hose leading from the PCV valve to the carb/manifold area. The top hole in the PCV valve had already been plugged by my mechanic. I decided to change the vacuum hose and PCV valve, and I plugged the top PCV hole like the old valve was. Now the noise is laouder. I finally tracked it down today and it's the new PCV valve, which is buzzing/rattling loudly, even when I pull the valve out of the valve cover. Anyone out there hear of this happening, and does it mean anything?
Old 03-29-2011, 07:20 PM
planehunter's Avatar
planehunter planehunter is offline
planehunter has a good reputation on FTE.planehunter has a good reputation on FTE.planehunter has a good reputation on FTE.
Sounds like something is hooked up wrong. The PCV vents the engine to the intake (basically). Take a piece of paper napkin and lay a corner of it over the hole in the valve cover and do the same thing to the PCV after it is out of the valve cover but the vacuum hoses are still connected. All of this is while the motor is running. While the paper is over the vent on the valve cover, it should be blowing up gently, more as you rev the motor. The PCV should hold the paper to it with mild suction, more as you rev it up. You should also get a vacuum diagram and check all the hose routings.
sluggish acceleration in 4.6 Aviator 78_79ford Explorer, Sport Trac, Mountaineer & Aviator 29 08-28-2015 06:24 PM
PCV valve replacement in 351 EFI ... what I learned b4hntn 1978 - 1996 Big Bronco 19 07-14-2015 08:17 PM
Underhood buzzing noise - PCV? PMDRACER Modular V10 (6.8l) 0 10-20-2011 02:09 AM
PCV valve Conanski 1987 - 1996 F150 & Larger F-Series Trucks 11 06-12-2009 12:04 AM
PCV Location on early 60s Y block... deyomatic 1961 - 1966 F-100 & Larger F-Series Trucks 4 12-17-2008 08:52 PM
Tags
bronco, buzz, buzzes, buzzing, buzzingpcvvalve, change, f150buzzingvalvevalvecover, f250, ford, humming, noise, pcv, sound, v10, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
