The turbo "Y" pipe - Ford Truck Enthusiasts Forums
The turbo "Y" pipe
Old 03-29-2011, 04:55 PM
Carolina Dually's Avatar
Carolina Dually Carolina Dually is offline
Carolina Dually is starting off with a positive reputation.
The turbo "Y" pipe
My wife and I just recently bought ourselves a 2003 F350 dually. Because the previous owner didn't take care of ir properly we have inherited all the problems due to neglect. However, we are slowly getting these issues solved. The first, was finding a reputable mechanic. We have just taken and spent $1400 to replace the FICM and EGR (FICM screw/pin test prove it bad). We now face an issue with the Y-pipe that goes to the turbo needing to be replaced. According to mechanic, this is a dealer replacement. Is this true or can a reputable muffler shop replace it?
Old 03-29-2011, 08:39 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Welcome to FTE. In future posts, be sure to include the fact that you have a 6.0 motor since several engines were available in 2003.
To answer you're question, we really need to figure out what he is calling the Y pipe. Did he show you or describe what the problem is? The Turbo has a Y shaped collector on the back of it that your bellowed up pipes connect to. Those will be dealer items, or if you don't mention it's for a Ford, you can also get them from an International dealer. Those 2 parts are not something that usually go bad, even with neglect, so I'm curious as to what happened to yours.
Old 03-29-2011, 08:46 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Powerstroke Diesel forum.
Old 03-29-2011, 09:32 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
turbo has to be removed to replace the section that is bad. only way I know of.
Old 04-01-2011, 11:23 AM
Thanks for the replies. The diesel tech did describe this piece as a collector that connects to the turbo. He says that there is a crack/hole in the flex piece of the Y-pipe.
Old 04-01-2011, 04:04 PM
hott-rodd hott-rodd is offline
hott-rodd is starting off with a positive reputation.
Cheezit, are you saying you have to pull the turbo to get the y-pipe out?
Old 04-01-2011, 04:24 PM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
Im not going to speak for him, but I believe thats what he is saying...
I would have to agree with him also.
But a muffler shop ehh I am not to sure...
How inclinded are you to working on your own truck?
I dont think its too bad of a job if you have patience and the tools to do so.
Old 04-01-2011, 04:26 PM
wulfman wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
Yes he is , and yes you do i just did mine pulling the turbo is the easy part. The bolts holding the pipe together are a PIA but doable
Old 04-01-2011, 04:29 PM
Quote:
x's 2
I think getting the bolts and nuts on the pass side is easier then the driver side.
Just my 0.02
Old 04-01-2011, 07:14 PM
cheezit's Avatar
there both easy after you figure it out...
but yes I am. it may be possible to get the y-pipe out by removing the trans but thats way to much effort.
Old 04-02-2011, 08:38 AM
When I called the dealer to see how much it would be to replace my up pipe, he said they might remove the tranny to replace it.
Old 04-02-2011, 05:10 PM
cheezit's Avatar
typical advisor
Old 04-04-2011, 12:16 PM
Thanks everybody.
Damn egr delete..
I'm going back to my original thought that the best (cheapest and easiest) delete is to weld up the cooler on both ends. No need to mess with up-pipe or support it.
How much $$ for a y-pipe?
Old 04-04-2011, 12:46 PM
PartsGuyEd is like 170 and like 25 shipping under 2 bills to your house. My local dealer was 285 plus our nice sells tax, almost 300. the welding thing works pretty good if its done right. I left my egr valve in and plugged in looks like stock.
Old 04-06-2011, 09:41 PM
Turbo "Y" fixed
Quote:
Originally Posted by hott-rodd View Post
Thanks everybody.
Damn egr delete..
Hott-rodd: Just the y-pipe that connects to the turbo cost me $276.60. This does not include all the other little parts for doing the job.
The mechanic gave me the piece that came off my truck (6.0 L), and sure enough there was a hole in the flex joint. There was exhaust soot all over the spot where the holes is at. I notice now that there is better take off and that aweful smell of exhaust coming into the cab is gone.
Hopefully, all this truck will need is a little TLC to get it where it needs to be.
Transmission rebuild! pjcat Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 04-06-2015 05:58 AM
2003 6.0 dually KBOFVA 6.0L Power Stroke Diesel 3 10-22-2014 06:46 AM
Need reliable Diesel Repair shop near Conroe lauraj Texas Chapter 2 05-01-2013 11:05 AM
Input Courtney Williams 6.0L Power Stroke Diesel 32 01-07-2013 10:43 AM
y pipe and oil leak question cajun250 6.0L Power Stroke Diesel 16 01-05-2012 10:00 AM
Tags
2003, 60, 60l, 97, diesel, exhaust, f250, f350, ford, forum, pipe, powerstroke, replace, size, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
