140v or 10k mod?
Old 03-29-2011, 12:52 PM
tshrager's Avatar
tshrager
tshrager is offline
140v or 10k mod?
I have been reading about the 140v and the 10k mods. These seem to be relatively easy and cheap to do. I only have a 6637, will these be ok to do, should I do one and not the other or both at the same time? I have heard the 10k will keep your idle higher. Thanks for the help
Old 03-29-2011, 12:55 PM
Robbgt's Avatar
Robbgt
Robbgt is offline
You can do them both at the same time. They're not doing the same thing
IIRC: The 140v IDM will open the injectors faster and keep them open longer. The 10k mod makes the pcm think you need more fuel than you actually do. Someone can correct me if i'm way off with that, but I think it's close. Some have the idle issue and some don't. I didn't see much performance gain from the 10k, so went to a 5.7K on a switch (made idle choppy). That wasn't enough so I went with a chip. The 10K is cheap, and fun to play around with, but you're going to get bored of it and want more power. Time to save for a chip!
Old 03-29-2011, 01:08 PM
Talyn's Avatar
Talyn
Talyn is offline
ICP mod is a good one.
The 140 volt IDM mod wont really do much.
Midnight Mods: ICP Resistor Mod – Version 1
here is how I did it before I got my chip.
Old 03-29-2011, 01:15 PM
clean '97's Avatar
clean '97
clean '97 is offline
From what i understand the pcm is tricked into increasing oil pressure to your injectors for snappier fuel delivery.
This mod did not affect my idle at all and increased my lower end significantly.
Well worth the $6.00 while saving up for a chip
Old 03-29-2011, 01:23 PM
Robbgt's Avatar
Robbgt
Robbgt is offline
^^ Yup, can't argue with the cheap price while saving for a chip.
Old 03-29-2011, 10:04 PM
tshrager's Avatar
tshrager
tshrager is offline
Yeah money is tight so I don't see a chip coming anytime soon. So just a 10k and a 4.7k resistor and a block? Thanks for the help
Old 03-29-2011, 10:15 PM
540milotalon's Avatar
540milotalon
540milotalon is offline
Are we sure the 10K mod delivers more power? I might try it on the new '95 I put on the road.
Old 03-29-2011, 10:23 PM
rideracelivemx7's Avatar
rideracelivemx7
rideracelivemx7 is offline
there was a thread put a year or so ago, maybe even longer when it was dyno proven with several variations of the resistor mods were tested. every truck is different and will respond differently. its not a HUGE gain but its a nice seat of the pants gain
Old 03-29-2011, 10:29 PM
540milotalon
I know some on here don't like them and some apparently don't like the 140V IDM. I feel the seat of the pants rule works on that IDM. A parts supplier that sells them told me the 10K "didn't do anything", that's why I never tried it. But of course they sell tuners and chips. I never felt they were leading me on. As a matter of fact they have helped to diagnose problems when they didn't get a sell. But you say dyno proven, hard to disregard. Especially when you're on a budget.
Old 03-29-2011, 10:35 PM
chicagodragon's Avatar
chicagodragon
chicagodragon is offline
when i played around with it, i put several combos on a gang switch so i wouldnt have to keep getting out of the truck. i could go from stock to 20k while on the fly and feel the difference
Old 03-29-2011, 10:37 PM
chicagodragon
i love the 140 mod. some of the cheap chips you see on ebay are just the 10k mod in a fancy case
Old 03-29-2011, 10:47 PM
540milotalon
Thanks all, I think I'll try it on the '95.
Old 03-29-2011, 10:50 PM
chicagodragon
the 15.6k worked best for me. but everybody is different. keep an eye on your egts!
Old 03-29-2011, 11:07 PM
540milotalon
The EGT gauge should be next. We only have it on the '87 with banks sidewinder. I imagine the wire size/length has something to do with resistance as well, could this not cause some of the inconsistency in results?
Old 03-29-2011, 11:11 PM
chicagodragon
i see where you are coming from, but i dont think it would be enough to matter. i think it only 5 volts we are dealing with.
Quick Reply: 140v or 10k mod?
