Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 03-28-2011, 11:33 PM
BigBadBob BigBadBob is offline
Garage is empty, add now
BigBadBob is starting off with a positive reputation.
Transmission slipping at low speeds
My 07 Eddie Bauer Expedition 4x4 is slipping at low speeds, usually between 20 to 40 mph. I'm not even sure if "slipping" is using the right terminology, but it feels sort of like the tranmission jerks a few times, then corrects itself and it's smooth driving after this. During this jerking period, it feels as if the engine will stall. Although it rarely happens when I hit highway speeds, such as 60 mph or higher, it has jerked going at high speeds as well. The engine does have a little over 80,000 miles, but other that this annoying jerking, my Expedition runs as good as the day I bought it. I haven't had any other major issues. I change the oil every 5,000 miles using full synthetic oil. Anyone have suggestions as to what is causing this?
  #2 (permalink)
Old 03-29-2011, 06:15 AM
tseekins's Avatar
tseekins tseekins is offline
2011 Ford F-150
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Quote:
I'll lay odds that a transmission flush will correct this behavior. Do you tow anything?
__________________
Tim
SCPO United States Coast Guard Retired
2011 F-150 XLT 4x4 Ecoboost
2010 Ford Focus
2004 Expedition XLT 4x2
FTE Guidelines
  #3 (permalink)
Old 03-29-2011, 07:09 AM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
Changing the fluid is worth a try. It took care of a problem I was having on low speed down shift.
__________________
2013 Explorer Limited
87 Ranger, XLT
  #4 (permalink)
Old 03-29-2011, 08:52 AM
Quote:
No, I don't tow anything at all. I use to own a 1993 Ford Taurus many years ago and when that started slipping, the culprit turned out to be the transmission filter. I know you can't compare the the old transmission in the Taurus to the one in my Expedition, but it's just a thought. Other than that, I'll try the transmission flush.
  #5 (permalink)
Old 03-30-2011, 09:52 PM
jdm5630 jdm5630 is offline
jdm5630 is starting off with a positive reputation.
i am having the same problems on my 07
  #6 (permalink)
Old 03-30-2011, 11:32 PM
I brought in my Expedition to my local Xpress Lube for a transmission flush. The bad news is, the service guy told me he did NOT have the MERCON SP ATF made specifically for this transmission. He said either go to the dealer to buy the Motorcraft Mercon SP fluid or buy a generic version from an auto parts store. I stopped by at "O'Reilly Auto Parts" and did find a Mercon SP approved fluid made by "Global". I've never heard of that brand before, however, should I really be putting this aftermarket type fluid in my transmission? What are the risks?
Also, I asked if my 07 had a transmission filter and turns out it does. I could not find a part number for this in the owner's guide, which is odd. Why would Ford omit this from the owner's guide? The guy pulled up 2 different types of tranny filters on his computer that fit an 07 Expediton, but he couldn't figure out which one was the right one for my vehicle. Any suggestions?
  #7 (permalink)
Old 03-31-2011, 05:33 AM
tseekins's Avatar
2011 Ford F-150
I'm not so certain that I would use a generic fluid. A complete flush at a Ford dealer runs $159.99 in my area. i'll bet that most are near that.
You may have to do the work and remove the filter and take it to the parts guy so he can match it. What a PITA.
Considering that volume that these transmissions and torque converters hold and the cost per quart of the Mercon product, a flush is only a few dollars more, 99% of the fluid is exchanged and you don't have to do the work.
__________________
Tim
2010 Ford Focus
FTE Guidelines
  #8 (permalink)
Old 04-01-2011, 05:14 PM
On my previous post, I said that it did have a transmission filter. I was told this at the O'Reilly Auto Parts store. I finally brought it in to the dealer today to get the complete flush done. When I asked the service technician to change the tranny filter as well, he said it did NOT have a filter. Several hours later, I picked up my Expedition and the slipping and jerking seemed to have disappeared. I drove it for at least 10 miles, however, as I got closer to home, it seemed to jerk once when traveling 55mph. Can't say if it was my imagination or because I was going uphill? This was weird, but I hope it doesn't happen again.
  #9 (permalink)
Old 04-03-2011, 07:21 PM
I have bad news. The annoying jerking is back. Now, it seems to jerk at around 40mph, where as before, it would jerk between 20 to 40mph and sometimes above 60. I don't know what what else to do. Do you guys have any suggestions?
__________________
2012 Explorer 3.5L
2013 Mustang GT
  #10 (permalink)
Old 04-04-2011, 05:47 AM
tseekins's Avatar
2011 Ford F-150
You'll need a diagnostic check. It may not be transmission related at all. But, you still got a much needed transmission flush.
__________________
Tim
2010 Ford Focus
FTE Guidelines
  #11 (permalink)
Old 04-04-2011, 01:10 PM
Thanks for the reply. That'll be my next step. Yeah, I'm glad I got the flush done, it needed that anyway. Like you said, it may not be transmision related. On the day I picked up my Expedition from the dealer, the service technician said the old tranny fluid wasn't that dirty and it did not have an odor of burnt oil, which normally would have indicated bigger problems with the transmisson. I was thinking it might be a bad sensor, but the check engine light has not turned on.
__________________
2012 Explorer 3.5L
2013 Mustang GT
  #12 (permalink)
Old 04-04-2011, 02:07 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Need to have the dealer drive it with you so they can see what is going on.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #13 (permalink)
Old 04-04-2011, 06:08 PM
rgilbert rgilbert is offline
rgilbert is starting off with a positive reputation.
Sounds like a bad coil pack. I had a similar "slip" before that was a bad coil pack.
  #14 (permalink)
Old 04-07-2011, 12:43 PM
berry1234's Avatar
Did you figure this out?
__________________
  #15 (permalink)
Old 04-07-2011, 01:16 PM
Quote:
Nope, my dealer found it. Happened two different times, but both times it felt like my transmission was slipping.
Tags
02, atblow, changing, explorer, f150, filters, freestyle, high, jerking, low, slipping, slips, slow, speed, speeds, stop, transmission, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
