IDI Performance
You can get a great used kit off eBay for less than $1000 easy now. I just checked out kits like mine where the winning bid was $900 and a few others that were less. You will dump $900 in your truck anyway by trying to build a better intake, exhaust, perhaps electric fans to keep a horsepower drain off the belt. Just bite the bullet and get a turbo, you will get plenty of power. Many little thing can be done to improve power, nothing even comes close to a turbo - there is a reason that stock diesels have come with them for the past 17 years.
An N/A engine with the exhaust opened up and more air in will definetly make a big difference. Just adding the dual 2-1/4" exhaust on my first IDI made a good bit of difference. Didn't get around to a better intake though.
Yes, a turbo is the most substantial gain but it does come with a price tag!
For many folks who don't use their truck for business, the $1k price tag can be hard to swallow in tough times.
All I'm saying is that a better breathing N/A engine is usually more than enough for what many guys use their pickups for...commuting to work, with the occasional trailer towing.
My bone stock 6.9 has plenty of nuts for what I do. In the low end, it flat out rocks. Just today, I was hooked up to the 12' tandem axle dump trailer and with it loaded up with landscape debris I could still let the clutch out at idle in 1st gear with 3.55 gears. I just idle around the farm in 1st gear, or let it idle in 2nd gear. And yes, I give it about 1/2 throttle in 1st gear and I could still get the rear tires spinning in the hard packed dirt.
At the end of the day, a better breathing N/A engine will do fine for some low-budget folks such as myself
What is the intent of the truck? Hauling heavy? Just want a little more oomph? Or is it for fun?
Oh, and a turbo will make a HUGE difference at areas high above sea level where the air is thinner...
Lol I actually drive a First Gen Stroker myself, its a '96. Was just wondering how powerful the IDI's can get, im trying to look at an 86 6.9 in my area... Id like to pick it up as a project truck, see what I can make the Ol' Girl Do lol
ChrisandAlex1
2010 - 2014 Ford SVT F150 Raptor
62
04-24-2013 11:20 AM
RacinNdrummin
30
04-17-2013 08:44 AM
