Opinions on 89 F-250 4x4
Sorry for the long post ahead of time. I am looking at buying a 89 f-250 4x4 with a the efi 351 for a extra plow truck. The guy wants $1200. The truck body wise is in good shape for the year and being from the north. I know the guy selling it he is a friend. He bought the truck with a blown motor and put the 351 in the truck, it burns a small amount of oil but nothing major. 4 wheel drive works and all interior stuff, radio, heater, lights work. My questions are .... Are these trucks good trucks? Are they easy to work on? It does seem that there is very little electrical wiring to deal with. Did the 351 efi come in this year truck or is it a newer motor? Can the front end of these trucks handle the weight of a plow without to much problems? I just don't want to buy something that is not going to do the job I need it to. I wish it had a solid front axle, but o well. I am pretty mechanically inclined, I work on my Powerstroke with no problem it is just going to take me a min to get used to working on a gas motor again. So what are your guys thoughts? Thank you for your help.
I had thought about the front tire thing. I can deal with that cause I am only looking at a max 8 ft straight blade no v or anything. I just don't want to get something that is a pain to work on and such. It does need the transmission shift points worked on as well as the idle adjusted. But other then that right now it is good I think. Are those hard to adjust on these trucks?
Received 3,102 Likes
on
1988 was the first year for the 351w EFI. Try to find out if the front axle is a Dana 44 or a Dana 50. A 50 will hold up a lot better to the plow, but a 60 is a bolt-in swap. You also might want to consider add-a-leaf springs in the front to help with the weight.
Do not adjust the idle! There's an adjustment on the throttle body but don't touch it. If it doesn't idle right then fix the real problem. Clean out the throttle body and check for vacuum leaks. Also clean or replace the IAC and the idle should improve dramatically.
If the tranny doesn't shift right that also indicates a vacuum problem so I would definitely be checking it out for a leak.
In general, these are very tough trucks that are pretty easy to work on.
on
BillyBobFord
21
06-26-2010 06:51 AM
straightexhaust
16
05-14-2007 08:27 PM
ScottInTexas
15
04-24-2004 09:26 AM
