gas tank problems - Ford Truck Enthusiasts Forums
gas tank problems
Old 03-28-2011, 09:42 PM
ItsAFord55's Avatar
ItsAFord55 ItsAFord55 is offline
ItsAFord55 is starting off with a positive reputation.
gas tank problems
ok i have a 1991 f150 with a 302 and i use my back gas tank cause the front one dosent show how much gas you have. everytime i get gas in the back tank i swear the gas is going some where one moment its high and next time i start it its lower??? i dont see any leaks. My old 351w used to get better gas mileage then this thing does.
Old 03-28-2011, 09:49 PM
KevinGnWV's Avatar
KevinGnWV KevinGnWV is offline
The village idiot.
KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.
Quoted this from an older post. Could be your problem.
"Vehicle Description: 1990-1993 Ford F-Series vehicles equipped with dual fuel tanks and 4.9, 5.0,5.8, or 7.5 liter gasoline fueled engines. Some vehicles can experience a cross tank fuel flow condition due to a damaged check valve in the fuel pump/sender assembly. Fuel may be supplied from one tank and some or all of the unused fuel may be returned to the other tank."
Old 03-28-2011, 09:55 PM
CWPottenger CWPottenger is offline
CWPottenger is gaining momentum as a positive member of FTE.
Yep, COMMON issue in these trucks.
Old 03-28-2011, 10:06 PM
ItsAFord55's Avatar
is there anyway to check for this?
Old 03-28-2011, 10:25 PM
Plain Jane Plain Jane is offline
Plain Jane is gaining momentum as a positive member of FTE.
Keep the front tank full if it doesn't leak and the pump works, then you can just work off the gauge on the back tank and use the front for emergencies. If the rear tank gauge keeps giving you varying information then you might have an issue with both sending units. Just a guess I am throwing out there for someone else to correct!
Old 03-28-2011, 10:33 PM
KevinGnWV's Avatar
The village idiot.
Quote:
If it is the cross-flow problem, it's possible it could over fill the front tank.
Old 04-09-2011, 12:39 AM
waskin27's Avatar
waskin27 waskin27 is offline
waskin27 is starting off with a positive reputation.
Yes it will flow out of the filler tube if the front is full, in 90 ford put intank high pressure fuel pumps in replace of the low pressure intank pump and deleted the high pressure pump on the frame rail along with the selector valve. To replace the selector valve they put check valves in the high press. intank fuel pump. In a nutshell when that check valve doesnt close all the way some of the unused fuel gets that is supposed to all go to the rear tank leaks or flows through the front tanks check valve (thus cross filling) . The only tank selector is the actual switch in the cab. The check valves in the pump are only closed through the pressure of the rear tank that the pump creates . the only 3 fixes are to unstick or clean out the check valve, or put a inline check valve in the front tanks return lines, or to replace the $110 fuel pump(just the pump not the sending unit). I would just put the inline check valves in which is what they did for that recall at the dealership. Or I guess you could just delete the front tank and delete the lines to and from, and also so rewire the selector switch in the cab or just dont use it. Yes I did a **** ton of research on this subject when I deleted the front tank on my 90 f150 . So trust me, I put the hours of researching in so you don't have to. Believe me it took along time to get enough matching answers from the right people, plus I already did it and it works fine. Peace im out!
Engine stalls on rear gas tank lindb40530 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 12-27-2016 08:45 AM
HELP.....1962 Falcon Ranchero - Need Gas Tank redfarmer84 Ranchero & 1961 - 1967 Econoline 0 06-17-2015 08:58 PM
Dual fuel tankS mike L 1987 - 1996 F150 & Larger F-Series Trucks 39 11-23-2014 09:33 AM
1973 F-100 Gas Tank Question pickenspolitics 1973 - 1979 F-100 & Larger F-Series Trucks 18 05-31-2014 09:15 PM
Leaky gas tanks pdqtimetrialer 1987 - 1996 F150 & Larger F-Series Trucks 10 10-27-2011 05:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
