94 f150 engine help.
I made a post about this same truck awhile ago and it wasnt too accurate. I have a 94 f150 with the 302 in it. This is an efi engine. The problem with the truck is that sometimes when you step on the gas nothing will happen. (This is usually when you are stomping on it) I was thinking something was maybe sticking?? I was wondering what some other peoples opinion is and what i could do to fix it. Thanks!
Ford Fuel Injection » Throttle Position Sensor (TPS) Not an expert but I think I would check the TPS as in this link.
Hopefully other opinions to follow.
Well thats exactly what i mean, nothing will happen. It is as if i had not stepped on the gas at all. it will only do this if i have taken my foot completely off the accelerator and it is coasting or if i am just taking off. it doesnt do it very often if i am already driving fairly fast like 20mph and up. it does it quite often though if i am at a dead stop or going under 10 mph.
ExGMguy
19
05-10-2010 12:08 PM
12engine
04-10-2007 05:20 PM
