Axle codes - Ford Truck Enthusiasts Forums
Axle codes
Old 03-28-2011, 06:28 PM
junkyardjeff junkyardjeff is offline
junkyardjeff is starting off with a positive reputation.
Axle codes
Other then a shop manual is there anywhere online where I can get the axle codes for the 87 to 91 trucks,I might be buying a 88 bronco to do a 2wd swap and if it has steep gears I will need the codes to look at trucks in the junkyards to find a more highway gear.
Old 03-28-2011, 06:33 PM
fdude64's Avatar
fdude64 fdude64 is offline
fdude64 is gaining momentum as a positive member of FTE.
search for vin decoder there should be something there
Old 03-28-2011, 06:47 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
From our own site:
Ford Axle Code Chart
Old 03-28-2011, 11:06 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm Ohio Ford Farm is offline
Ohio Ford Farm is gaining momentum as a positive member of FTE.Ohio Ford Farm is gaining momentum as a positive member of FTE.
13- Ford 9" 2.75 ratio 1981-83
13- Ford 8.8 4.11 ratio 1985-86
H3- Ford 9" ls 2.75 ratio 1981-82
H3- Ford 8.8 axle 4.11 ratio with limited slip 1985-86 (3800 pound)
14- Ford 9" 3.00 1981-1986
H4- Ford 9" 3.00 Limited slip diff 1981-86
15- Ford 9" 3.25 1981-82 and 2.73 in 1983
H5-Ford 9" 3.25 limited slip 1981-82 and 2.73 in 1983
16- Ford 9" axle 3.50 ratio (3750 pound)verified
H6- Ford 9" axle 3.50 ratio with limited slip (3750 pound)verified
18- Ford axle 8.8 3.08 ratio (3800 pound) 1983-86verified
H8- Ford axle 8.8 3.08 ratio limited slip (3800 pound) 1983-86verified
19- Ford axle 8.8 3.55 ratio (3800 pound) 1983-86verified
H9- Ford axle 8.8 3.55 ratio with limited slip (3800 pound) 1983-86verified
23- Dana 60-3 axle 3.54 ratioverified
24- Dana 60-3 axle 3.73 ratio verified
29- Ford Semi Float Sterling 10.25, 3.55 ratio
B9- Ford semi Float Sterling 10.25, 3.55 ratio limited slip diff
B5-Ford semi Float Sterling 10.25, 4.10 ratio limited slip diff
39- Ford full float Sterling 10.25 3.55 (single rear wheel)
C9- Ford full float Sterling 10.25 3.55 (single rear wheel) with limited slip diff
35- Ford full float Sterling 10.25 4.10 (single rear wheel)
C5- Ford full float Sterling 10.25 4.10 (single rear wheel) with limed slip diff
33- Dana 61-1 3.54 ratioverified
C2- Dana 61-1 3.54 ratio with limited slip diffverified
52- Dana 70-1 HD 4.10 ratio (8700 rating)verified
53- Dana 70-1 HD 3.54 ratio from 1983-86 (4.56 in 1982) (7400 rating)verified
E2- Dana 70-1 Hd 4.10 ratio with limited slip diffverified
49- Ford Sterling 10.25 dual rear wheel 3.55 ratio (7400 rating)verified
D5- Ford Sterling 10.25 dual rear wheel 4.10 with limited slip diff (7400 rating)
69- Ford Ford Sterling 10.25 dual rear wheel 3.55 ratio (8250 rating)
F5- Ford Ford Sterling 10.25 dual rear wheel 4.10 ratio limited slip (8250 rating)
__________________
Old 03-28-2011, 11:26 PM
court1100f court1100f is offline
court1100f is gaining momentum as a positive member of FTE.court1100f is gaining momentum as a positive member of FTE.
18- Ford axle 8.8 3.08 ratio (3800 pound) 1983-86verified-still accurate
__________________
my 1990s got the code 18 for the axle code and the axle tag corroborates the 3.08:1 Open Differential designation of axle code 18 so I suspect that stayed the same all the way through to the end of this body style of half tons
Old 03-29-2011, 11:07 AM
I am not 100% but I think this list is good up to late 90's or 2000ish.
Old 03-29-2011, 12:50 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Yeah those codes are good for any truck in this series.. 1987 - end of production.
Old 04-01-2011, 12:54 PM
Jimbo302's Avatar
Jimbo302 Jimbo302 is offline
Jimbo302 is gaining momentum as a positive member of FTE.
My 1995 F350 has the C5 code for the axle. I knew it was 4.10's but I wonder if it is limited slip. I am guessing it has the D60 front.
Old 04-01-2011, 03:49 PM
Quote:
Well if you look at the chart. It shows it as a 10.25 axle, single rear wheels, with limited slip.
Old 03-04-2014, 05:16 PM
infinite-foamies's Avatar
infinite-foamies infinite-foamies is offline
infinite-foamies is starting off with a positive reputation.
I am looking at a 91 with an axle code 65. Any ideas?
Old 03-04-2014, 05:37 PM
rla2005's Avatar
Quote:
Click on the link in post #3
Old 03-04-2014, 06:12 PM
Okay thanks, I had seen that but was not sure of which axle but I guess with Ford make it is safe to assume Sterling 10.25 or 10.5.
Old 03-04-2014, 06:17 PM
Conanski's Avatar
The only axles used in HD F-series trucks of this vintage was the Sterling 10.25 in semi float and full float versions.
Old 03-04-2014, 06:36 PM
Thank you.
Axle codes for 3.73 and 4.30 gears? bykr 6.2L V8 4 11-24-2016 02:52 PM
Axle code decipher LOOK HERE Truck Guy99 1987 - 1996 F150 & Larger F-Series Trucks 1 07-29-2014 07:48 AM
Axle code Truck Guy99 1987 - 1996 F150 & Larger F-Series Trucks 7 05-21-2014 11:38 AM
Axle codes Rtpjunior 1997-2006 Expedition & Navigator 22 02-03-2014 07:45 PM
What gears do I have? Truck Guy99 1987 - 1996 F150 & Larger F-Series Trucks 3 02-03-2014 05:34 PM
Tags
1987, 1988, 1990, axle, c5, code, codes, d5, decode, f150, f350, ford, hd, rear, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
