Harbor Freight scan tool - Ford Truck Enthusiasts Forums
Old 03-28-2011, 03:50 PM
TinyWonder's Avatar
TinyWonder TinyWonder is offline
TinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to behold
I'm prety sure that I know the answer to this question but I'm going to ask anyway.
My Brother-in-law gave me a Harbor Freight OBDII scan tool to use... will this work on our trucks?
CAN OBDII item #94169.
Thanks
Old 03-28-2011, 03:53 PM
JT250's Avatar
JT250 JT250 is offline
JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.
Try it and let us know.
Old 03-28-2011, 03:57 PM
empiretc's Avatar
empiretc empiretc is offline
empiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to all
for sure. it would be amazing if it does!
harbor freight = $1 store of tools
Old 03-28-2011, 04:15 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
I thought our truck were not ODBII compliant?
Old 03-28-2011, 04:18 PM
JT250's Avatar
I am not sure if they are OBD II compliant or not, but I thought my mechanic checked OBD II the other day when he hooked his scanner up to my truck. Somebody will chime in that knows.
Old 03-28-2011, 04:23 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
You will pick up some generic codes with it but not any PSD specific codes. So in a nut shell no it will not work. Sorry to be the bearer of bad new...........
onelionhunter onelionhunter is offline
onelionhunter has a very good reputation on FTE.onelionhunter has a very good reputation on FTE.onelionhunter has a very good reputation on FTE.
Codes
You will be able to read anything to do with smog codes, but none of the engine specific stuff.
In the case of my truck, I have a GPCM(Cali Truck), when my UVCH was coming loose, it threw a bad glow plug 7 error as that is a smog component. Its pretty limited in out applications though, as most anything of importance will not be read by it.
Old 03-28-2011, 04:39 PM
TinyWonder's Avatar
Quote:
That's prety much all I could have hoped for.
I didn't think it would work but I thought "what the heck".
I presume that it's only a reader and not going to mess with the PCM or other programing. Am I correct in this assumption?
The weirdest thing happened the other day. I was at Mc'D's and shut my truck off so they could hear me at the drive thru. When I started it up the CEL light came on for a moment and then turned off. I'm thinking that there is a stored code in the truck and I just wanted to see if this cheapo scanner would read it.
I would really like to get AE but just can fit it into the budget right now.
Old 03-28-2011, 04:49 PM
BillyBob69's Avatar
I have been looking for something I can run on my HTC Evo. I have seen alot that you can plug into your port and connect to it via bluetooth for live info and pulling codes but everything I find is for ODB II
Old 03-28-2011, 05:07 PM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
The trucks are OBD II compliant. That means you can read generic OBD II information. There are three things that can be looked at on the power-train with OBD II compliant devices. MAP, RPM, & MPH. Beyond that everything else is manufacture specific and therefore falls out side of the OBD II generic realm.
Most every OBD II device will only scan and read codes that are generic, meaning across all vehicle types. The ones for the phones are no different, or at least the four or five I have looked into.
Maybe if enough people ask AE, they will make an APP for that!
Old 03-28-2011, 05:32 PM
SteveH-CO SteveH-CO is offline
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
Earlier Powerstrokes are not OBDII compliant. Look at the sticker under the hood. I know that '05s diesels were OBDII compliant.
My '01 is J1850 PWM compliant. Some of the better code readers will read these codes. The cheapest of the el-cheapos will not.
Old 03-30-2011, 09:31 AM
TinyWonder's Avatar
Well night before last I gave the el-cheapo code reader a shot.
It powered up to the OBDII port and I started the scan...
It said no codes were present but then it went through a bunch of emissions stuff... all of these fault areas said N/A... not a big suprise here.
Basically, I'm glad that I didn't have to pay anything for the el-cheapo scanner. I'm saving my $ for AE.
Old 03-30-2011, 09:54 AM
BillyBob69's Avatar
Quote:
Thats what I am waiting for! Just enough to pull codes, and do live monitoring of what the PCM watches...RPM, 0 - 60 etc..the fun stuff to watch.
**waiting to hear...There's an app for that!**
Compression test kit harbor freight 3000gtman Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 10-25-2016 08:26 PM
Harbor Freight Cen-Tech Scan Tool PaxtonShelby 1999 to 2016 Super Duty 2 11-12-2014 03:58 PM
Code Readers or Diesel Scanner Questions Crazyotto1 General Diesel Discussion 5 11-01-2013 09:09 AM
pittsburgh brand tools from harbor freight mrak Garage & Workshop 80 02-14-2013 09:48 AM
Press: blockheadbob Garage & Workshop 7 11-22-2005 10:19 PM
Tags
73, 79, 94169, ford, freight, harbor, ii, live, obd, reveiw, scan, tachometer, tool, truck, truckgate, videoscanning, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
