new member needs ideas
Hi all. I have been reading your forum for a while now. Sure are a lot of helpful smart people out there with a lot of info. Thanks for the ideas .
I'm having a problem passing the ca. smog check. (check eng. light on) always starts and runs good. Has IDM codes. Have 6 inj. with high to low open codes.p 1271 72 77 74 76 77. Things I have done so far are. Bought AE , Replaced all injectors 30,000 ago when eng was rebuilt, replaced valve cover gaskets and harnesses Used the ford repair clips also, Replaced the eng harness plugs to the valve covers, Replaced the ecm and the idm with rebuilts from auto computer exchange. Ohmed all the harneses till I'm blue while shaking and wiggling them From idm plug and back all ohm at 2.9 Was thinking of trying inj. solinoids next. Any other ideas out there? Thanks for all the help and info.
First let me say thanks for the warm welcome guys. My trials have been so ongoing with this truck that in my first post I may have omitted some of the things I tried. I did replace the Idm and the cpu with rebuilts. They cleared some of the other codes this truck had. I'm just dowm to the Idm codes now. Tried a local shops spare Good test Idm and had the same codes. The eng. runs fine just the cel is on. I have removed the eng. harness and did a continuity test on all of the sensor wires back to the big sq. plug at the left valve cover. I also put new batts and cleaned th cables really good last week.
I will today clean all the connections for power supply and grnds. Good idea thanks
