1974 4x4 Power Assist steering swap
Old 03-28-2011, 03:41 PM
ungerp's Avatar
ungerp
ungerp is offline
I have a 1974 F-100 4x4 with manual steering. I would like to convert to at least the power assist unit. What do I need for this and does anyone have sources for these units/parts?
thanks
Pat
Old 03-28-2011, 06:51 PM
armstrongfordtrucks's Avatar
armstrongfordtrucks
armstrongfordtrucks is offline
I did this years ago by using a steering box from a F-150. 78 and 79 bronco is the same. All I did was line it up with everything, c-clamp it to the frame and drill new holes. You will also have to get a tapered ream for the steering arm to fit. You will need to find a power steering pump and bracket for your engine. You should have either a 6 cylinder or 360 v-8. the cars had power steering on them they used the 390 engine, go salvage yard hunting.
Old 03-28-2011, 07:33 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
Old 03-28-2011, 07:53 PM
ungerp's Avatar
ungerp
ungerp is offline
Thanks guys. I had missed all the pieces in LMC. My big concern is to find the actual power steering/assist box for the 1974. I hate to get all the pieces and not be able to find a box. I was also told the column length is different vice a manual set up.
Old 03-28-2011, 11:13 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
The power assist steering system is a POS.. prone to leaks, core charges are super-high, and just a PITA. Good luck finding parts in the yards... if so, then it will likely need to be rebuilt anyways.
I HIGHLY recommend the integral PS swap from the 76-79 4x4s... and the T-style linkage. Did it to my 73 and it is a pleasure to drive. My total cost was $360...I'll post up the parts list with my costs and sources if you want see it.
Alternatively, Benchworks Steering has a kit for around $1000.
Old 03-29-2011, 09:11 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by armstrongfordtrucks
The cars had power steering on them they used the 390 engine, go salvage yard hunting.
1971: Last year for 390 engines in Passenger Cars. The P/S linkage, gearboxes and etc, power assist P/S parts used in Passenger Cars will not work on trucks.
P/S pumps:
1965/77 Passenger Cars (w/o Hydroboost); 1966/77 F100/350; 1972/77 Bronco: The P/S pumps are essentially the same, have a steel reservoir.
In 1978, Ford changed the P/S pump on everything (except Econolines), has a plastic reservoir.
The P/S pressure hoses used on 1977 and earlier pumps will not work with the 1978 and newer pumps. '
1978 and later P/S pressure hoses have a straight end with an O-ring on it used in conjunction with the qwik dis-connect fitting used on 1978 and later pumps.
Most of the 1977 and earlier P/S pump mounting brackets will not work on the 1978 and newer pumps. The P/S pulley's will work on both types.
Old 03-29-2011, 09:31 AM
HIO Silver's Avatar
HIO Silver
As an addendum and not to NumberDummy's post above, 76 was the only year for FE-equipped Dentside 4x4s with integral steering.
Contact Borgeson if you want to use the later style pump on an FE.
Old 03-29-2011, 11:27 AM
NumberDummy
You must be referring to F100/150's, because...
Only Power Assist P/S was available in 1973/77 F250 4WD's (High Boys). Two types were used: Garrison & Bendix.
Old 03-29-2011, 03:38 PM
HIO Silver's Avatar
HIO Silver
Yessir... Thanks for the clarification.
Old 03-29-2011, 05:17 PM
ungerp's Avatar
ungerp
ungerp is offline
Please send your parts list and sources. I thought I looked at Benchworks already, but maybe when I asked for a kit for a '74 F-100 that is what through them off.
Old 03-29-2011, 10:17 PM
HIO Silver's Avatar
HIO Silver
74 F100 4x4 Integral PS Swap
First, a few notes:
1. I sleeved my frame instead of simply drilling holes for the mounting bolts.
2. You can source the pressure fittings new from Jegs or Summit but I had no clue on what to get so I brought both pressure hoses to a hydraulic shop and got a custom line fabbed up.
3. The 78-79 T-style drag link and tie rod is waaay better then the Y-style found in 76-77.
4. After removing the tie rod from the donor, loosely reinstall the tie rod and measure how much "stick-out" the tie rod shank is exposed and keep a record of that measurement. You'll likely need to ream your D44s steering arm holes because the later tie rod has a thicker shank. I thought they were all the same but alas, they were not.
Here is the list (and less expensive if you can beg or borrow a reamer!):
<TABLE style="WIDTH: 361pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=481 x:str><COLGROUP><COL style="WIDTH: 166pt; mso-width-source: userset; mso-width-alt: 8082" width=221><COL style="WIDTH: 143pt; mso-width-source: userset; mso-width-alt: 6985" width=191><COL style="WIDTH: 52pt; mso-width-source: userset; mso-width-alt: 2523" width=69><TBODY><TR style="HEIGHT: 14.25pt; mso-height-source: userset" height=19><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; WIDTH: 166pt; HEIGHT: 14.25pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=19 width=221>Part</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; WIDTH: 143pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 width=191>Source</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; WIDTH: 52pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 width=69>Cost</TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=16>PS Steering box, 79 Bronco</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25>Pick N Pull</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 x:num="49.99"> $ 49.99 </TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=16>Drag link, 79 Bronco</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25>Pick N Pull</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 x:num="22.99"> $ 22.99 </TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=16>Tie-rod, 79 Bronco</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25>Pick N Pull</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 x:num="14.99"> $ 14.99 </TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=16>Pressure hose, 79 Bronco</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25>Pick N Pull</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 x:num="7.99"> $ 7.99 </TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=16>Steering shaft</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25>Pick N Pull</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 x:num="11.99"> $ 11.99 </TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=16>PS pump, Ford w/ pressure hose</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25>Pick N Pull</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 x:num="29.99"> $ 29.99 </TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=16>PS pump bracket, FE</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25>Pick N Pull</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 x:num="10.99"> $ 10.99 </TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=16>PS belt, FE w/PS</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25>Autozone</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 x:num="8.81"> $ 8.81 </TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=16>PS drive pulley, FE</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25>Pick N Pull</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 x:num="11.99"> $ 11.99 </TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=16>Hardware</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25>Ace Hardware</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 x:num="25"> $ 25.00 </TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl27 height=16>Pipe</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl27>Home Depot</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl28 x:num="15"> $ 15.00 </TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=16></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl29>Subtotal</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 x:num="209.73" x:fmla="=SUM(C2:C12)"> $ 209.73 </TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=16></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26></TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=16>Tapered reamer, 7-degree</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25>Speedway Motors</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 x:num="69.99"> $ 69.99 </TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl27 height=16>Custom pressure hose (labor& matls)</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl27>S & S Line and Tubing</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl28 x:num="74.94"> $ 74.94 </TD></TR><TR style="HEIGHT: 12pt" height=16><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=16></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl29>Subtotal</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 x:num="144.93" x:fmla="=SUM(C15:C16)"> $ 144.93 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=17></TD><TD style="BORDER-BOTTOM: windowtext 2pt double; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl30></TD><TD style="BORDER-BOTTOM: windowtext 2pt double; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl31></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=17></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl29>Total</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: white; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl32 x:num="354.66" x:fmla="=C17+C13"> $ 354.66 </TD></TR></TBODY></TABLE>
HIO SILVER, AWAY!!... that was my battle cry after everything was hooked up, bled, and I could steer my rig with one hand AT A STANDSTILL. Ahhhhhhh.
Old 03-29-2011, 10:41 PM
ungerp's Avatar
ungerp
ungerp is offline
HIO Silver, all is pretty self explanatory. The steering shaft I presume is for the column. Is there any particular part numbers for the steering gear box. Last as far as positioning of the box is it in the same area as the old box?
Thanks for all the help. I will let you know how things are going.
Pat
Old 03-30-2011, 09:36 AM
HIO Silver's Avatar
HIO Silver
Pat
1. No particular PN for the steering box so long as it comes from a 76-79 half-ton 4x4.
2. The steering box moves back nearly touching the track bar bracket. The conversion will result in the pitman arm pointing forward instead of towards the rear with the manual box.
Oh, mroe notes: You'll have to collapse the later model steering shaft so it will fit. Second, the Bronco steering shaft I used had a 3/4-36 single "D" and I had to grind a flat spot on the steering column shaft. Lastly, using a later model steering shaft will create two electrically isolated sections. Install a jumper wire across the steering shaft sleeve and at the rag joint or else the horn circuit will not ground.
Old 03-30-2011, 12:15 PM
ungerp's Avatar
ungerp
ungerp is offline
I know I am asking a lot, but could you possibly snap a couple digital photos of some of this stuff, tie rod/drag link set up. Box position and steering column shaft and send them to me at pat.unger@gmail.com.
It looks like I can get most of this from Autozone, since junkyards are scarce down here, a little more money, but all is new or reman and guaranteed.
Thanks,
pat
Old 03-30-2011, 01:16 PM
HIO Silver's Avatar
HIO Silver
No problemo... we're here to help, right? I'll get to it this PM.
No wrecking yards? That's no fun!!! Where are you located?
Quick Reply: 1974 4x4 Power Assist steering swap
