1974 4x4 Power Assist steering swap - Page 2 - Ford Truck Enthusiasts Forums
Old 03-30-2011, 07:21 PM
ungerp's Avatar
ungerp ungerp is offline
ungerp is starting off with a positive reputation.
Southern AZ next to the Mexican border. Most stuff they have is all mid 80's and up. They said they could find me a gear box, but wanted $325 for it. I can get a reman from Autozone w/limited lifetime for $335 which includes the core charge. A lot higher, but I think worth it in the long run.
Thanks
Old 03-30-2011, 07:28 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
$335.00 is a lot higher than $325.00?
Before you buy that blotto-zone gear box, go to redheadsteeringgears.com and read all about it.
These gearboxes have a built in flaw that causes them to begin leaking in a very short time.
And, since only the seals kits are available, that so-called reman gear box is nothing more than a re-sealed gearbox.
If you live in Douglas, you could dig a tunnel to make some extra dinero.
Old 03-30-2011, 10:54 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
I know I am asking a lot, but could you possibly snap a couple digital photos of some of this stuff, tie rod/drag link set up. Box position and steering column shaft and send them to me...
Pics taken and pics sent to your gmail account.
Old 03-31-2011, 10:40 AM
ungerp's Avatar
Need to correct that email I gave you it is ungerpat@gmail.com
Old 04-01-2011, 12:28 AM
HIO Silver's Avatar
Pics sent again.
Old 04-01-2011, 01:26 AM
Dirt racer's Avatar
Dirt racer Dirt racer is offline
Dirt racer is starting off with a positive reputation.
Might be cheaper to go the route that HIO Silver talking about, but I did a power steering box swap on my 75 F-100 4x4. Mine had the power assist setup. Leaked most of the time and didn't have that much power steering to it. I used a 79 bronco steering box but had to have the worm gear changed out so it turns the opposite way. Had it rebuilt at the same time. I used the manual drag link which you should already have. Didn't have to ream out anything. Only had to drill 2 holes in the frame for the box. One lined up ok. I have a borgeson steering shaft already. Did shorten it some. Running a 90's power steering pump using the original mount from the original 360, did have to modify some. Running a 429 now. If you look in the Articles up top, there is a guy in Arizona that did this. I sent my box to him for the rebuild. That was like 7 or 8 years ago now. This truck never steered better than after I did this mod. Still working great.
Old 04-01-2011, 01:28 AM
Dirt racer's Avatar
Old 04-01-2011, 01:29 AM
Dirt racer's Avatar
Old 03-16-2013, 09:09 AM
Mrshields777 Mrshields777 is offline
Mrshields777 is starting off with a positive reputation.
Dirt racer, you said there was an article up top where a guy changed the worm gear like you did. Where did you purchase the reversed worm gear?
Old 03-16-2013, 12:32 PM
HIO Silver's Avatar
Quote:
He's referring to the Tech Thread Hyperlink sticky at the top of the 73-79 forum page. Go to the last update.....The West Coast Bronco article is the one you want to read.
Basically, you use the worm gear out of a 2WD box and use it in a 76-79 4WD box to reverse the direction of the pitman arm (pointing to the rear).
Oh, lemme throw in the gratuitous "Welcome to FTE"!
Old 03-16-2013, 03:36 PM
crazy96863's Avatar
crazy96863 crazy96863 is offline
crazy96863 is gaining momentum as a positive member of FTE.
Here is my write up on the reverse geared box.
http://m.ford-trucks.com/forums/show....php?t=1144182
Old 03-16-2013, 03:47 PM
crazy96863's Avatar
BTW, I still have the box and pitman arm. Unused since doing this. It seemed that it would have issues with clearing the core support. I would be interested in seeing a more detailed write-up of this type of installation. None the less, I plan on doing a HIO styled install when I get around to it; yes I went and grabbed another which is also in my garage. Kinda hoarding them at this point.
I would be willing to part with the reversed gear box for what I have into it; about $100. I have to stress it is unused which means untested although everything is pretty straight forward on these. The worse case scenario would be a leak but it all looks good. Using this, even if you sent it to redhead for a rebuild, might allow you to have a 'built better than new' box for the same price as a chinese rebuild box. I doubt it needs the redhead treatment though. Let me know.
  #28
Old 11-08-2014, 08:39 AM
wallyworld wallyworld is offline
wallyworld is starting off with a positive reputation.
got 78 f-150 ps, will it fit on 71 f-100 2wd
  #29
Old 11-08-2014, 05:52 PM
HIO Silver's Avatar
Quote:
Since ya didn't provide any detail on exactly what "78 f-150 ps" parts ya grabbed, read this: How to Install Power Steering in a 2WD F100/250/350 - FORDification.com
Carefully note the differences in pitman arms & linkages.
If ya still got questions, then start a thread cuz this 'un concerns 4x4s... and put over in the Bumpside (67-72) forum.
  #30
Old 11-08-2014, 08:22 PM
Robrt32's Avatar
Robrt32 Robrt32 is offline
Robrt32 is starting off with a positive reputation.
I got rid of my power assist a few months ago. I got lucky and found a 74 in the junk yard that somebody had already converted. They didn't reverse the worm gear they just moved the steering box back toward the rear of the truck and drilled new holes. They shortened the steering shaft. It took me maybe 2 hours and I got power steering I can turn with 1 finger with 33x12x50's on the front. I love it
1974 F250 Belts. 3505740 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-21-2015 04:09 PM
Sorry but yet another high boy power steering question. H 3 1973 - 1979 F-100 & Larger F-Series Trucks 0 07-19-2014 04:57 PM
original owner 1974 F250 kool4x4 New Member Introductions 2 07-15-2014 03:23 PM
1974 F-100 power steering patriotf100 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-28-2013 11:18 PM
Highboy bendix power ram seal kits montana_highboy 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-09-2012 08:00 PM
Tags
1974, 1978, 4x4, 78, 79, assist, drag, f100, f250, ford, leaks, link, power, steering, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
