2005 STX Hard to start when cold.
Old 03-28-2011, 12:03 PM
nagel76's Avatar
nagel76
nagel76 is offline
Question 2005 STX Hard to start when cold.
I have a 2005 STX with 107,000 miles on it. When it is cold you have to turn the key on for 5 seconds twice then start it. When it is warm it will start like it always did. When the temperature outside is 60 or above you have to do the key thing about 5 times. I think it is my fuel pump but I would like some more input. What do ya'll think? Puzzled in Missouri!
Old 03-28-2011, 05:40 PM
dgndngrngr84's Avatar
dgndngrngr84
dgndngrngr84 is offline
I thought fuel pump too as I was reading. Sounds like you gotta keep priming the pump to get the pressure up enough for it to start. How old is your battery though? Also have you changed the fuel filter yet or is the original one still on there? If not I would throw on a new one and try that before tackling the fuel pump.
Old 03-28-2011, 07:06 PM
Coskid's Avatar
Coskid
Coskid is offline
Agree with Eric. Start with fuel filter if it hasn't been done in a while and maybe get the battery tested. Some more information on your past care will help the people around here with more advice on where to go if these don't do the trick.
Old 03-28-2011, 10:29 PM
nagel76's Avatar
nagel76
nagel76 is offline
Battery is about 2 years old and never had a problem. Fuel filter was changed about 2000 miles ago and it made no difference to the way it starts. Took it to a garage and they put it on the machine that cleans the injectors and valves and heads. it also made no difference.
Old 03-29-2011, 01:43 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
2004 xlt 5.4 is offline
There is a fuel module on the rear frame X member behind the spare tire check it to see if it is corroded as they trap dirt and water at the frame if any holes in it need new one aprox $ 100.00 and they have a spacer to keep it off the frame.
evan.kelly978
Ford Truck Parts for Sale
03-22-2014 10:44 PM
TheLandYacht
New Member Introductions
12-22-2013 10:28 AM
ddiercks
1999 to 2016 Super Duty
12-14-2013 09:30 AM
Quick Reply: 2005 STX Hard to start when cold.
