2005 STX Hard to start when cold. - Ford Truck Enthusiasts Forums
Old 03-28-2011, 01:03 PM
nagel76 nagel76 is offline
nagel76 is starting off with a positive reputation.
Question 2005 STX Hard to start when cold.
I have a 2005 STX with 107,000 miles on it. When it is cold you have to turn the key on for 5 seconds twice then start it. When it is warm it will start like it always did. When the temperature outside is 60 or above you have to do the key thing about 5 times. I think it is my fuel pump but I would like some more input. What do ya'll think? Puzzled in Missouri!
Old 03-28-2011, 06:40 PM
dgndngrngr84's Avatar
dgndngrngr84 dgndngrngr84 is offline
dgndngrngr84 is starting off with a positive reputation.
I thought fuel pump too as I was reading. Sounds like you gotta keep priming the pump to get the pressure up enough for it to start. How old is your battery though? Also have you changed the fuel filter yet or is the original one still on there? If not I would throw on a new one and try that before tackling the fuel pump.
Old 03-28-2011, 08:06 PM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
Agree with Eric. Start with fuel filter if it hasn't been done in a while and maybe get the battery tested. Some more information on your past care will help the people around here with more advice on where to go if these don't do the trick.
Old 03-28-2011, 11:29 PM
Battery is about 2 years old and never had a problem. Fuel filter was changed about 2000 miles ago and it made no difference to the way it starts. Took it to a garage and they put it on the machine that cleans the injectors and valves and heads. it also made no difference.
Old 03-29-2011, 02:43 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4 2004 xlt 5.4 is offline
2004 xlt 5.4 is starting off with a positive reputation.
There is a fuel module on the rear frame X member behind the spare tire check it to see if it is corroded as they trap dirt and water at the frame if any holes in it need new one aprox $ 100.00 and they have a spacer to keep it off the frame.
Trucktober is upon us and it's time to get off the porch! Chat and BS thread. All welcome. 77&79F250 Missouri Chapter 636 10-31-2015 10:30 AM
Jefferson City Kane96 1999 to 2016 Super Duty 0 01-17-2015 10:44 AM
For Sale: 360 FE Engine (Missouri) evan.kelly978 Ford Truck Parts for Sale 1 03-22-2014 11:44 PM
Young New Guy from Missouri TheLandYacht New Member Introductions 11 12-22-2013 11:28 AM
Cold weather diesel fuel additives? What do you use? ddiercks 1999 to 2016 Super Duty 9 12-14-2013 10:30 AM
Tags
05, 1979, 2005, cold, f150, ford, fuel, hard, pump, ranger, start, starting, stating, stx, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
