1994 F350 Turbo Diesel 7.3L won't start - Ford Truck Enthusiasts Forums
Old 03-28-2011, 08:20 AM
dnewref dnewref is offline
dnewref is starting off with a positive reputation.
I changed the oil seals on my truck's oil cooler and now truck won't run. I suspect the Fuel Injector Control module is not firing. Is there any sensor that is related to the oil system that could prevent the injectors from firing? What is the best way to debug the FICM (Fuel Injecto Control Module)?
Old 03-28-2011, 08:23 AM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
Youre in the wrong forum, this is pre-power stroke.
Old 03-28-2011, 08:25 AM
bashby's Avatar
Old 03-28-2011, 04:39 PM
My motor is not a power stroke.
Old 03-28-2011, 04:50 PM
bashby's Avatar
Then you dont have a injector control module. There is a mechanical fuel pump that pulls fuel from the tank and supplies the injection pump. (also mechanical) Is there any smoke coming from the tailpipe when you crank it? White smoke is unburnt fuel.
Old 03-28-2011, 06:37 PM
No smoke is coming from tail pipe. If I inject starter fluid into the breather it will fire up until I take starter fluid away. Right after I finished putting oil cooler on, the engine was started and ran for 20 seconds and stopped. It has not hit a lick since. Except for the starter fluid. Another mechanic says it is the crankshaft sensor.
Old 03-28-2011, 06:51 PM
wreckinball's Avatar
wreckinball wreckinball is offline
wreckinball is gaining momentum as a positive member of FTE.
post a pic of the engine bay, that we can tell you for sure. Sounds like the mechanical lift pump is worn out and not supplying fuel. Pics bro, we can do a lot with pics.
Old 03-28-2011, 06:59 PM
johnboggs21's Avatar
johnboggs21 johnboggs21 is offline
johnboggs21 is starting off with a positive reputation.
Quote:
All the things indicate you have one of the first powerstrokes. IM gonna take a wild stab and say your truck also has a 5 spd. Post a pic of the engine bay and we can tell you for sure, but the words in red are all powerstroke words.....
Old 03-28-2011, 07:03 PM
bashby's Avatar
if you have an IDI diesel (non powerstroke), you have no crank position sensor either. When you turn the ign on, it sends power to a fuel shotoff valve up on the injection pump. When that valve is open, fuel can flow and when the engine cranks, it should start.
Old 03-28-2011, 07:29 PM
eatont9999's Avatar
eatont9999 eatont9999 is offline
eatont9999 is starting off with a positive reputation.
If it is a Power Stroke, I would suggest filling up your top oil so the HEUI injectors actually have pressurized oil to fire them. Chances are it drained out when you drained the rest of the oil and it is not being recirculated properly.
This guy explains the top end oil in this series of videos.
http://www.youtube.com/watch?v=V1oHA...eature=related
Old 03-29-2011, 09:45 AM
I now believe that this truck is one of the first DI (Direct Injected) powerstroke motors with the HEUI (hydraulically actuated electronic unit injection). Looking at the videos posted bu eatont9999, My motor looks very much like this one with the top end oil reservoir. I measured the the oil level in this reservoir and found it to be 6.5" below the top of the reservoir. Tonight when I get home, I will try adding oil to this reservoir.
Old 03-29-2011, 11:13 AM
thats what we all thought, if you look at the engine bay and see a black cover that has DI or direct inujection on it, you sir, are a stroker!! haha.
Old 03-29-2011, 11:28 AM
bashby's Avatar
Usually the tag on the fender will say "power stroke" if thats what it is. Mine has a tag on the tailgate that says "diesel"
Old 03-29-2011, 07:20 PM
eatont9999's Avatar
I hope that fixes your problem. It is a terrible feeling when your truck won't start and you have work to do. I would recommend watching all of PowerstrokeHelp's videos. He is pretty through and knows his strokes. If you don't have proof of service records for your truck, I would suggest that you go through PSH's longevity series and perform the work you can so that you know it has been done.
Good luck.
Old 03-31-2011, 01:22 PM
Well I gues you might have wondered. Did I every get the truck started, and the answer is no. Even though I'm in the wrong forum, your responses have helped me out a lot with this (my first) deisel. So I ask that you continue to help me with this problem.
So here is where I am... The EEC (diagnostic system) doen not work. I only get a solid on signal from the Data out pin. My local mechanics (that have also been helping me out) were convinece that the oil cooler tube is on backwards.. I finally took it off last night and took it to a mechanic today and he agreed with me there is no way to get this tube on backwards. The cooling tube can be mounted either way. But I did notice the by-pass valve on the oil filter housing was missing... So now I have to find another housing... B/c Ford does not sell just the valve. So when I get the new (or used) housing, I have a few things to try.
1) Fill the filter up with oil before installing it.
2) fill the top end with oil and use the bleed port on the side of the housing to bleed out all the air in the cooling tube.
3) work on figuring out why the EEC does not work.
By the way, this truck was running just fine, prior to trying to fix this oil leak. If anyone has some additional ideas, I'm all ears.
1995 f250 won't start! Help! Desireg 1987 - 1996 F150 & Larger F-Series Trucks 3 09-25-2015 05:22 PM
won't start. gogzilla 6.0L Power Stroke Diesel 1 04-09-2015 03:28 PM
Cranks, won't fire, no engine codes Jxltrucking 6.0L Power Stroke Diesel 9 01-15-2015 12:03 AM
1211 and 1212 codes countrycar 1999 - 2003 7.3L Power Stroke Diesel 8 11-21-2012 07:16 PM
91 E350, 351W, EFI - WON'T START. clman 1968-2013 Full Size Vans 9 11-16-2012 12:49 PM
Tags
1994, 1997, 3, 350, 73, 73l, diesel, ford, fuel, injection, pump, start, testing, turbo, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
