1993 ford f350 7.3 idi tach issues - Ford Truck Enthusiasts Forums
Old 03-28-2011, 02:18 AM
mirage5058 mirage5058 is offline
mirage5058 is starting off with a positive reputation.
My 93 ford f350 7.3 idi tach doesnt work when trying to start the truck tach jumps up and down after its running it doesnt move,i checked the wires at the unit by the oil fill and wires are in good shape and unit seems good,any ideas what may be causing this issue would be greatly appreciated ?
Old 03-28-2011, 07:59 AM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
Did you try wiggling the wires and connector, sometimes the fan wind will cause wires to do silly things. You could remove it and test it........
My blurb....
A dead tach sender should/would send the automatic (E4OD) trans into a "failure management mode" (limp mode) with harsh engagements and firm shift feel and an abnormal shift schedule. It has no effect on a manual trans only the Tach readings.
Check the wires where they exit the big nut on the oil filler housing , known to short out due to bare wire.....
Replace the tach sender on the oil fill housing a big 1" nut with 2 wires. Ford only part Engine RPM sensor E5TZ-17B384-A about $50. You can remove and clean it but usually changed later too.
You can test it too, hold it in the air away from ferrous metal, using an ohm meter lead on each wire you need DC resistance between 2000-3000 ohms.
Old 03-29-2011, 06:48 PM
93 ford 7.3 idi tach issues
Well i think i found out why tach wasnt working correctly, dash caught on fire today must have been short somewhere in harness now i need complete dash harness,anybody got one? nothing but problems for me one right after another,Thanks for info on cleaning the sensor didnt get a chance to try it.
Old 03-29-2011, 09:26 PM
94 smokin stroker's Avatar
94 smokin stroker 94 smokin stroker is offline
94 smokin stroker is starting off with a positive reputation.
I know where i can get you a entire dash or anything you need off a idi parting it out want me to get the number for the guy
Old 03-30-2011, 01:04 AM
tach issues
Hello if you could get the number i would apreciate it,
7.3 idi tach help? fordf150f250 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 01-07-2017 02:35 PM
What's this? and does it affect shifting? bart f-350 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 11-27-2015 06:24 PM
Tach not working drpaul311 1994.5 - 1997 7.3L Power Stroke Diesel 59 12-21-2014 01:22 AM
Tach Lead 88/90f-250IDI Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 07-22-2014 11:08 AM
Tach Question 94 IDI Turob Gen 1 driver Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 03-11-2012 10:36 AM
Tags
1993, 1994, 73, desiel, diesel, f350, filter, ford, idi, oil, stopped, super, tach, tachometer, tech, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
