1983 ford transfer case rotation
I think I heard that I can rotate the transfer case on the 83 Ford c6 transmission I am using in my latest project. Is that true? It looks by the bolt spacing where the case hooks to the spacer between it and the trans that it would work. Other than shift linkage, it looks like it would work. Can anyone help me? Thanks.
I'm not sure if mine is a Borg/Warner or not. Is there an easy way to tell? Regardless, I will definitely check to see if that will be an issue. I think I only need to rotate one bolt hole to get the clearance I need so hopefully that will still be able to work. Is that the only issue you know of? Is it one of those things I will just have to try and see if it physically works? Either way, thanks for your help. This definitely will give me things to look for.
vtgboss
1997-2006 Expedition & Navigator
29
10-10-2018 07:35 AM
frank washington
11-07-2016 10:44 PM
TFR
01-25-2005 12:39 PM
