Symtpoms of a warped rotor when not hitting brakes
you probably won't feel it as a vibration. you might hear a little scrape when the pads hit the rotor and you have the windows open. this is how i've heard it before. plus the vibration when hitting the brakes.
Can you describe the vibration better? Is is on acceleration? at a certain speed? is it there when braking? Do you feel it in the steering wheel?
It happens the worst at 40-45 mph when im just tapping the gas or not hitting it at all. When i get into the gas it seems to stop. I replaced the rear u joints last year. I also have 2 bad ball joints up front. I can throw it into neutral while its vibrating and it dosent go away. The whole inside of the cab vibrates and has always pulled slightly to the right
Also note: Mine does not pull and the ball joints are good.
My F350 did this but violent ended up being the stabilizer. Also needed ball joints but, the stabilizer fixed it b4 it got the rest of the parts.
viperbluelx
06-04-2007 06:30 PM
