429 cj
i have a 429 cj and it has ford racing valve covers,It has a pvc valve that goes to the carb/intake.when i pull the oil fill out there is vacume.There is a port on the side of the oil fill for a hose should this be hooked up somwhere.it had a cap on it. Is this vacume normal
On the stock air cleaner housing there is a plastic nipple that plugs into the air cleaner housing and connects to it's own special filter in side the housing. That nipple is what I used to do a PCV for my 428CJ with a 406 3X2 setup with custom ram air. Drilled hole in the base of the ram air container that fit on the carbs inside the air filter element and installed the nipple and connected the inlet hose to that.
429 cj
ok now i remember that little filter inside the air cleaner!!pretty porus sponge like filter.my truck has after market air cleaner, but i'll go to the parts store and see what they have for nipples that will work.Also looks like oil is coming out of the dipstick.has dipstick right in front by water pump, is this common do you know?
kell2784
11-07-2009 04:31 PM
BlueOvalfan85
03-06-2005 07:09 PM
popeye69
06-29-2004 12:48 AM
maverickgear
04-11-2004 04:40 AM
bbtkd
06-08-2002 04:57 PM
