Go Back   Ford Truck Enthusiasts Forums > Marketplace > Want to Buy > WTB - Parts & other
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
  #1 (permalink)
Old 03-27-2011, 05:51 PM
BORDERBUM's Avatar
BORDERBUM BORDERBUM is offline
1977 Ford F-150
BORDERBUM is starting off with a positive reputation.
Need 400m 4 speed flywheel for 77 4x4 1/2 ton
like it says I need a 77 4x4 half ton flywheel for a 4 speed. Im looking all over the place for one and I had several before things started causing them to fall through the cracks. Let me know asap, thank you
  #2 (permalink)
Old 03-31-2011, 01:25 AM
lostinfords's Avatar
lostinfords lostinfords is offline
Garage is empty, add now
lostinfords is starting off with a positive reputation.
not sure if these were off a 351m or the 400, but I believe they are the same bolt pattern, just need to verify the width/diameter of the clutch you are using...2 different ones, I have 2 in NJ
Click the image to open in full size.
  #3 (permalink)
Old 04-01-2011, 08:10 PM
mark a.'s Avatar
mark a. mark a. is online now
mark a. has a very good reputation on FTE.mark a. has a very good reputation on FTE.mark a. has a very good reputation on FTE.
I have one from a 78 351m-400. 3/4ton, 4x4, diaphragm clutch. It's probably the same thing.
__________________
'79 F250 13" lift 42" Super Swampers
  #4 (permalink)
Old 04-05-2011, 11:54 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1977/82 351M/400: Two different flywheels. because two different sized clutches.
1977/79 F100/350 / 1978/82 Bronco / 1980/82 F150/350 / 1980/82 Econoline:
D7TZ-6375-D .. 400 Flywheel-Use w/12" Clutch / Marked: D7TE-CE
D7TZ-6375-E .. 351M Flywheel-Use w/11" Clutch / Marked: D7TE-DE
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #5 (permalink)
Old 04-05-2011, 02:50 PM
BORDERBUM's Avatar
1977 Ford F-150
Thank you for this info. This will save me some time and mess ups!
  #6 (permalink)
Old 04-05-2011, 03:17 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Workaholic
1978 Ford F-250
My Garage
77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold
PM sent for help, stop on by the FTE Missouri chapter.
__________________
77&79 F250 Rich & Penny
77 351M auto, factory a/c add a leaf/33x12.50's
78 (79 headlights) 460 4 spd, factory a/c and 35's
79 351M 4spd 6" Skyjacker Edelbrock-Holley-Hedman 35's
99 Ranger 4x4 Ext Cab Flareside V-6, 98 Expedition EB 4x4
71 Bronco 302 35" Boggers 5.58 gears spool/locker
  #7 (permalink)
Old 04-15-2011, 12:23 PM
nothercrash's Avatar
nothercrash nothercrash is offline
1984 Ford F-250
My Garage
nothercrash is starting off with a positive reputation.
I have a flywheel marked D7TE-6380-DC, not sure why the discrepancy in numbers, but figure out if you can use it.
This thread says you can: http://www.ford-trucks.com/forums/63...e-6380-dc.html
I have an auto. AleX
__________________
79 F150 4X4. 408. Np435, the clunk. Np205. 9" + HPD44, 3.50's. 31" BFG A/T's. True duals, flowmaster 44's. Full custom interior. 5 color primer and weld on patches!
Henry Ford, puting bow ties out of style since 1903!
Tags
400, 50, 6380, 77, big, block, d7te, d7te6380dc, d7tece, dc, f150, flywheel, flywheels, ford, specs, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
