Help with violent shaking of car
Hi,
I'm new to the forum.
Help with this problem: Once in every few days the truck starts to shake aggressively while on the road. Its like going through a very rough gravel road all of a sudden, felt through steering column. I have to pull over and hit the brakes and bring truck to full stop before it goes away. Then it's gone. Any thoughts before I start to take it to mechanic. Is it shock related, brake related, etc?? Any ideas, comments, suggestions, similar experineces.
By the way, my truck model is the 2005 F150 XLT TRITON.
Thanks.
Thanks.
It happens randomly. On the highway, down, up. It's as if the front of the truck is being driven off road. I've had the tires rotated, and re-balanced, shocks and springs looked at visually by my mechanic. And off course when he takes it for a test drive nothing happens.
I'm wondering if something in the suspension is getting stuck. But then why would braking the car to a complete stop eliminate the problem?
Could it be something to do with the 4X4? It's an automatic gear box.
Jose41
Jose41
I was just recently reading about a different forum member who said his truck shook like a dog. It was in an F350, but same concept. He had it happen to him randomly as well. It wasn't until he did a full lock turn on his steering wheel that his tie-rod snapped off.
Basically, check your front suspension and steering system. I doubt this has to do with the 4x4 system.
When I asked Ford to diagnose the same problem the only thing they did was install a steering stabilizer. Check to see if your has one I'll bet it doesn't. Look into a steering stabilizer and it should go away. You can pick up one just about at any parts store or your favorite online shop. That is what they did to fix the problem for the shop here cause I took it to them under warranty. At that time there were no TSB's on the problem. Don't know if there is any yet. Should be recalled after the amount of people having issues. Hope this helped.
Jose41, just like JoSHN said, check for a worn out tie rod end. I had a pick-up from anouther manufactur for years. It did just what you are describing. But would clear up for awhile with new tires. I think the stablizer was replace twice, fornt end re-alligned many times, all by places that sold tires. Finally I took it to a shop that just did front end and drive line work. They found the problem right away, totally worn out tie rod end. In my opinion, never have front end work done by a place that sells tires.
The parking break is a drum break. If it's sticking, how does applying the disk stopping break release the drum parking break? They are two seperate components.
I posted what I remember. Point was to have the parking break checked out.
Sorry for any confusion
On a different note.....really don't think you can put a stearing stabilizer on a rack and pinion stearing system. I know of the death wobbel of the older F-350 with strait axel. A stearing stabilizer worked on that application.
