E40D shift problems
What 628 is saying is that for the RPM, the gear the Computer has selected along with or not it applied the TC Clutch does not agree with the information it is getting from the PSOM.
So the computer thinks it has detected that the Transmission has slippage.
I would get that speedometer working right before doing anything to the transmission.
youll be looking at the Tone Ring, make sure its not bent or missing teeth.
If the rear diff has a LS in there be sure to add your friction modifier otherwise the LS will get damaged.
just curious what size tires are on the truck? its possible the PSOM needs recalibrated to the current tire size. it this isnt set correctly to what your running it will cause the tranny to not shift properly or accuratly.
you replaced the TPS, but did you make sure its operating in its proper range?
don't know if you read earlier post kemi...when I unplug the vss...the truck shifts good...it has a new vss in it but I don't know how to check if it is good. The truck has stock everything....tires and all (so far...lol) will I be able to tell what the tone ring is just by looking at it? ...I cant find crap as far as pics of my diff...thanx
